How to use a spot weld timer #1868308
07/11/15 05:08 PM
07/11/15 05:08 PM
NY usa
540challenger Offline OP
NY usa
So I picked up a miller spot welder lmsw. I have never used a timer before. Any tips on what do or not to do?
Re: How to use a spot weld timer [Re: 540challenger] #1868310
07/11/15 05:13 PM
07/11/15 05:13 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I weld and own a Miller. Can't do better on a unit. Look online for a manual for your unit.
Re: How to use a spot weld timer [Re: Pynzo] #1868361
07/11/15 06:51 PM
07/11/15 06:51 PM
NY usa
NY usa
Well the timer works extremely well, however the steal is 3/16 thick looks like I need to order shorter tongs being that is the max thickness if the machine will report next week on progress hopefully.
Re: How to use a spot weld timer [Re: 540challenger] #1868924
07/12/15 06:52 PM
07/12/15 06:52 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You got a machine that can spot weld 3/16"? Holy crap, how big is this thing?
Re: How to use a spot weld timer [Re: 6PakBee] #1868931
07/12/15 07:02 PM
07/12/15 07:02 PM
NY usa
NY usa
Re: How to use a spot weld timer [Re: 540challenger] #1869000
07/12/15 08:44 PM
07/12/15 08:44 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Wow, I'm impressed.
shock
Re: How to use a spot weld timer [Re: 540challenger] #1870859
07/15/15 12:50 PM
07/15/15 12:50 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Good luck spot welding 3/16" with that; I have a liquid cooled Miller 20 KVA and a larger liquid cooled, air powered 30 KVA unit in my fabrication shop and neither would work on anything that heavy....rated or not.
...and if you read that data sheet, the 3/16" rating for that unit is COMBINED thickness; i.e. BOTH pces.....it's rated for 16ga galv.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: How to use a spot weld timer [Re: DPelletier] #1873711
07/19/15 07:24 PM
07/19/15 07:24 PM
NY usa
NY usa
The combine thickness is the metals is 3/16. Never said I was welding 2 pieces of 3/16
Re: How to use a spot weld timer [Re: 540challenger] #1874354
07/20/15 03:14 PM
07/20/15 03:14 PM
DPelletier Offline
DPelletier  Offline
Well that's good. In the industry, when we say we are welding 3/16" or 10ga or whatever that is the thickness of the individual pces.
spot welds look good.
Cheers,
