i have installed one power window set up in my 1969 charger and the adjustable small track that is rivited to the window with the large plastic push rivet...well it pivots each time the window motor is engaged and bangs up again the glass and i think it is going to break it..
is there a pad i need in there or am i out of adjustment..
has anyone else had this problem..to be clear i am talking about the six inch track that is put on the door glass by the half inch or so plastic rivet that is two pieces and this is the track that engages the window regulator large plastic circle piece that drives the window up..this is the same piece as a crank window has, but the power window is slightly different as again it has some adjustment on it..
