Page 5 of 6 1 2 3 4 5 6
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1873833
07/19/15 09:54 PM
07/19/15 09:54 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Va58,
Please post your pics here rather than emailing them, I created this thread so that we can all see each others 340 details and learn from them.
beer
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1873969
07/19/15 11:47 PM
07/19/15 11:47 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
I believe Federal Mogul supplied the blades & clutches IIRC......
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874031
07/20/15 01:01 AM
07/20/15 01:01 AM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
here is a few Engine details mid 20k miles original. hope posting photos like this is ok.
http://s24.photobucket.com/user/Tim_Downey/slideshow/72%20Duster%20340%20engine%20details
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874032
07/20/15 01:04 AM
07/20/15 01:04 AM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
It's not a question of keeping this info a secret. Totally new posting procedure and I'm borderline computer illiterate
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874036
07/20/15 01:12 AM
07/20/15 01:12 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Understood, links are fine. If you need help posting your pics just email them to me and I'll post them for you, no problem. bugframes@msn.com
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874040
07/20/15 01:16 AM
07/20/15 01:16 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Va58, what is the number stamped on your idle stop solenoid? Is that a white grease pencil stripe on it?
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874041
07/20/15 01:16 AM
07/20/15 01:16 AM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
This car has very few things changed since new.Original owner added another horn for some reason and a tach. Also, that darned white nylon wire tie in one photo.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874043
07/20/15 01:18 AM
07/20/15 01:18 AM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
Yes.. White grease pencil. This particular car is owner by friend.
I just looked at photo again. not grease pencil. A type of white paint marker of some sort.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874051
07/20/15 01:28 AM
07/20/15 01:28 AM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
Also notice in photo of dip stick. from stop up, appears to be dipped or painted in black paint. very worn now but appears very thin.. almost ink like.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874055
07/20/15 01:33 AM
07/20/15 01:33 AM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
Show absolutely no sign of any blue paint and appears properly aged to be original. Dipstick was one of the items added after engine painted I believe.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: Va58] #1874056
07/20/15 01:34 AM
07/20/15 01:34 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, my 71 340 dip stick was the same, so was my NOS one, EXTREMELY thin black paint that falls off with little contact. Also, your negative battery cable is unpainted as was my 71 engine's. I'd be interested in knowing what bolt head markings are on the fasteners (all of them).
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874159
07/20/15 10:38 AM
07/20/15 10:38 AM
dmoore Offline
dmoore  Offline
72 Duster340,auto,3.23 SPD of 419, non-ac car, 36,000 miles...
Note the different nuts utilized for wiring connections.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874162
07/20/15 10:45 AM
07/20/15 10:45 AM
dmoore Offline
dmoore  Offline
Neutral safety wiring harness clip secured by transmission bolt, oil press sending unit.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: dmoore] #1874164
07/20/15 10:48 AM
07/20/15 10:48 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Dmoore, does your distributor hold down clamp have engine paint on it?
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874165
07/20/15 10:48 AM
07/20/15 10:48 AM
dmoore Offline
dmoore  Offline
Another view of coil connections & partial brake booster vacuum supply hose.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874167
07/20/15 10:51 AM
07/20/15 10:51 AM
dmoore Offline
dmoore  Offline
Well choke, no paint on choke assy, however mounting bolts were painted.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: autoxcuda] #1874173
07/20/15 10:58 AM
07/20/15 10:58 AM
dmoore Offline
dmoore  Offline
Originally Posted By autoxcuda
btw, car....
Steve, Is this a V5X car?
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874175
07/20/15 11:00 AM
07/20/15 11:00 AM
dmoore Offline
dmoore  Offline
Hmmm,I will have to check it again Scott..
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: dmoore] #1874254
07/20/15 12:56 PM
07/20/15 12:56 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
btw, car....
Is that side stripes? If so yes.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1874263
07/20/15 01:06 PM
07/20/15 01:06 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
V5X = vinyl side moldings no stripes
