Injectors in 06 diesel #1873638
07/19/15 05:29 PM
07/19/15 05:29 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
How difficult are injectors to change in my truck? Any special tools needed? Would you go new or rebuilt?
Re: Injectors in 06 diesel [Re: cudaman1969] #1874258
07/20/15 01:01 PM
07/20/15 01:01 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
https://youtu.be/uGBQEmwyMMo
pretty easy. I bought the snap on feed tube tool like in the video.
Re: Injectors in 06 diesel [Re: chrisf] #1874452
07/20/15 05:39 PM
07/20/15 05:39 PM
fredericksburg,va
fredericksburg,va
Thank you good video
Re: Injectors in 06 diesel [Re: cudaman1969] #1874875
07/21/15 02:38 AM
07/21/15 02:38 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
On cumminsforum, the consensus is that rebuilts are junk. Avoid them like the plague.
Sucks because new ones will run $2500
Plus side is that larger nozzle injectors are the same cost, so it's a great time to upgrade so that when your turbo needs replaced, you can upgrade it too
**Photobucket sucks**
Re: Injectors in 06 diesel [Re: cudaman1969] #1875006
07/21/15 12:16 PM
07/21/15 12:16 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I bought new ones for almost the price of rebuilt ones. I upgraded the fuel pump and filter as well. The rear ones are the hardest. I bought new feed tubes. I did not buy any special tools. Don't buy rebuilt injectors for sure.
