Need some help on Hemi Engine Break-In (Long)
#1873360
07/19/15 09:14 AM
07/19/15 09:14 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I started my fresh 426 Hemi yesterday for the first time and I have a couple problems.
First: 66 426 Hemi: now a 484 with Callies stroker crank, JE pistons, Manley rods. Crane H-244/362-2S-14 Cam (.568/.572) I am using stock heads, stock intake and (2) Carter 500cfm carbs. Using a Mallory 140gph pump with regulator. 1/2 line from pump to regulator, 3/8 from regulator to carbs. Also a 3/8 return line to the tank. Car is a 67 Coronet with 4-speed and dana with 4.10 gears.
Problems:
1) When pump is on it seems to make a knocking sound. I get fuel delivery though. The fuel gauge (small cheapo one off the regulator) bounces. I have it set I think to around 3PSI so it bounces 1-3.5 Is the regulator bad? should it make that knocking sound and bounce the gauge? Is the fuel set too low?
2) When I was breaking the cam in the headers started to glow red hot so I shut it down. This is after about 5 min of run time. Is this because of a lean condition?
So maybe I am answering my own questions, but do you guys think the 500 carbs are too small? fuel pump too small? regulator bad and set too low?
Other than that and some valve cover leaks it started up good and runs strong.
Thanks for reading and your help.
RS23L7 4-Speed
Re: Need some help on Hemi Engine Break-In (Long)
[Re: 67DodgeCharger]
#1873381
07/19/15 10:29 AM
07/19/15 10:29 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Need to advance the timing more, what is the timing set at now? The extra lift from the cam will make it hotter and you did not port the heads or intake so no increase in flow. More fuel pressure and check your plugs for lean conditions. Sounds like a nice car I agree. Timing probably late. High rpm during break-in might make exhaust glow also, so is it glowing at idle or at 2,000 rpm? Excessive lean or rich condition might contribute. Is knocking from fuel system components or engine? Need more info. Carbs are probably too small, but for top end. Probably pretty responsive for around town driving, light to light romps, but would choke off on 1/4 mile top end.
[image][/image]
[Re: sgcuda]
#1873383
07/19/15 10:34 AM
07/19/15 10:34 AM
Mopar_Mike
Danville, NH
Well when it started I went right to 2000-2500 for the break-in, have not idled it yet. Knocking is definitely from the regulator because I can turn on the pump before starting engine and it does it.
What would you think for carbs?
RS23L7 4-Speed
[Re: ahy]
#1873387
07/19/15 10:38 AM
07/19/15 10:38 AM
Mopar_Mike
Danville, NH
I am running a sump, lower than tank. 1/2" all the way to the regulator.
RS23L7 4-Speed
[Re: Mopar_Mike]
#1873930
07/19/15 11:18 PM
07/19/15 11:18 PM
Posts: 7,664 IN
ahy
IN
I am running a sump, lower than tank. 1/2" all the way to the regulator. That part sounds good!... just need to figure out the noise and bouncing gauge.
[Re: Cab_Burge]
#1874121
07/20/15 07:22 AM
07/20/15 07:22 AM
Mopar_Mike
Danville, NH
It did Cab, turned it up to 7psi and the noise went away and the needle steadied out but the carters I am running started to leak, or at least the front one leaked past the rods and also out the sides.
RS23L7 4-Speed
