Header tech; do smaller tubes,,,,,,,
#1872863
07/18/15 01:48 PM
07/18/15 01:48 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Work well if you can get them pretty much straight off the flange and out ten inches or better? I built 2 1/8 x 30 x 4 inch headers, and they seem to work well but after reading ANDYF's response on another thread I wonder if there might be enough benefit to try a different tube size, like two inch with a 3 3/4 collector. Andy, or anyone else have back to back data to show the difference? Here is a pic of my current tubes, and the new ones I could go almost exactly in line with exhaust flow at the flange, for an exit angle.
Re: Header tech; do smaller tubes,,,,,,,
[Re: gregsdart]
#1873167
07/18/15 10:10 PM
07/18/15 10:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What I try to do is get 1 cyl volume before the first tangent point.... the collectors should be in the range of 16" to 18" but that is based on other factors also... like RPM.... the primary length is also a important factor... if you want send me a PM and I'll run you engine through my header program EDIT this is the set I built for my 405ci... this is a 3 step.. 1 7/8, 2, 2 1/8... this is a 4"collector and 16" long EDIT Remember that your starting from the valve.. not the edge of the head so you have to add that in
[Re: MR_P_BODY]
#1873313
07/19/15 02:21 AM
07/19/15 02:21 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I sure do wish you were closer Mr. P. I'd love a lesson on building headers! I always admire your work.
[Re: gregsdart]
#1873337
07/19/15 04:42 AM
07/19/15 04:42 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Mr P, i remember the day you posted that pic of those headers almost 10 years ago and was blown away
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
