Inline Fuel Filter #1873038
07/18/15 06:09 PM
07/18/15 06:09 PM
NY
Beep Beep Offline OP
NY
I would like to add a fuel filter before my Holley Double Pumper Carb. I am running a 110gph mechanical pump. The Holley has a sintered bronze filter on the inlet of each bowl.
Should I use the sintered bronze filter or the steel mesh inline? The mesh is 40 microns and the bronze is 35 microns.
Re: Inline Fuel Filter [Re: Beep Beep] #1873091
07/18/15 06:57 PM
07/18/15 06:57 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I just use a standard fram metal canister type.
Re: Inline Fuel Filter [Re: Beep Beep] #1873099
07/18/15 07:09 PM
07/18/15 07:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Your on the right track thinking stainless screens with lots of pleats inside=hi dollar(like kinsler or someone like that? I'm sure there's others)On my street cars I use a factory repo hemi/440/6 vapor separator as my filter bolted to my fuel pump.
But you want 10 microns in that situation, between the pump and carburetor. I'd leave the sintered one in the carb too.
But really this kind of filter should serve your needs. It's 10 microns.
Re: Inline Fuel Filter [Re: ademon] #1873100
07/18/15 07:10 PM
07/18/15 07:10 PM
Cincinnati, Ohio
Cincinnati, Ohio
Which is a very good filter used in that situation(it's paper, not stainless), after the fuel pump. up
Re: Inline Fuel Filter [Re: Beep Beep] #1873105
07/18/15 07:20 PM
07/18/15 07:20 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use this style up by my carb which is like the factory type. Ron
Re: Inline Fuel Filter [Re: 383man] #1873200
07/18/15 10:37 PM
07/18/15 10:37 PM
I'd suggest a 10 micron name brand (Russell etc) high flow filter right before the "Y" chromed Holley inlet line and toss all other filters (with mech pump system only)
Re: Inline Fuel Filter [Re: Beep Beep] #1873273
07/19/15 12:50 AM
07/19/15 12:50 AM
NY
NY
Thanks guys for the feedback. I wanted to use a 6an connection filter, but I guess I could stick with the steel line setup.
