Storing a carb #1873126
07/18/15 07:56 PM
07/18/15 07:56 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Just pulled a Holley off the car, going with a different set up. What's the best way to drain/flush the carb? My plan is to use it on the big block next year so it'll sit on the shelf till then, don't want it to gum up with old gas.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Storing a carb [Re: busboy] #1873191
07/18/15 10:27 PM
07/18/15 10:27 PM
What I'd suggest is take off the bowls/metering blocks/plates/squirters/mixture screws (especially them)/everything & blast every passage with a 2 dollar can of brake kleen (use up the whole can)
Re: Storing a carb [Re: busboy] #1873211
07/18/15 10:55 PM
07/18/15 10:55 PM
scratchnfotraction Offline
yep, I open them up, wash them out with brake clean, spray them down with wd-40, install a fresh rebuild kit, seal it up in a big plastic zip-lock bag, then shelve it. ready to run.
if it is only going to be weeks, then I just dump it out, pump the fuel out the pumps and shelve it.
I have intakes that they sit on with air cleaners to keep them sealed up while on the shelf.
Re: Storing a carb [Re: busboy] #1873221
07/18/15 11:17 PM
07/18/15 11:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have blown them out with light air pressure, several times in the fuel inlet and the bowel vents, everywhere to get all the gas out of them off the motor. Sprayed some wd40 in the same openings and gave it another light blow. Plastic bag, worked for me.
Re: Storing a carb [Re: busboy] #1873362
07/19/15 09:23 AM
07/19/15 09:23 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Hmmmm.
I do nothing but drain the fuel out.
Re: Storing a carb [Re: BSB67] #1873428
07/19/15 11:57 AM
07/19/15 11:57 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
For a year I agree for longtime storage suggestions above sure cuts down on all that white crap growing inside & corn fuel eating rubber parts.
Re: Storing a carb [Re: busboy] #1873441
07/19/15 12:23 PM
07/19/15 12:23 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Just don't turn them upside down to dump the fuel and stir things up and clog the jets
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Storing a carb [Re: busboy] #1874500
07/20/15 06:57 PM
07/20/15 06:57 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I'd pull off the bowls AND all of the plates and gaskets. I've found gas behind the metering plate gasket on a vacuum secondary holley, in the hollow area where a power valve might go on the primary side of a carb. That gasket did not have an opening in it for the power valve but there was still gas behind it.
Re: Storing a carb [Re: Sixpak] #1874606
07/20/15 09:44 PM
07/20/15 09:44 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
I've had good luck dumping the gas out of the vent tubes and filling with sea foam. Work the accelerator pump and slosh it around inside and dump the excess and bag it
The little old lady from Pasadena is back!
