Re: Ram truck blend door repair
[Re: fastmark]
#1872664
07/18/15 12:42 AM
07/18/15 12:42 AM
Posts: 41 Maryland
regularjay
Maryland
I used a heatertreater kit on my 99 Grand Cherokee that involved cutting into the box and coupling the flaps for both sides up to one motor worked great for about 4 years till I sold the truck, easy hour long project that worked out fine.
79 Lil Red Express - I'll finish it someday 94 2wd Ram 1500 5.9 Donor for...??? 78 CJ7 4.2 with Clifford Cam, Holley 390, 4" on 33's 1992 W250 Cummins 2013 Ram 4X4 Hemi Crew Express 2005 Ex Cab Dakota 4x4 4.7 Daily Driver 1993 2wd Ramcharger 5.2/auto
[Re: regularjay]
#1872684
07/18/15 01:06 AM
07/18/15 01:06 AM
Posts: 289 Lowes
steve660
Lowes
I had same problem. Blend door broke off and landed on top of blower fan. Could here fan blowing hard but hardly any air coming out. I removed glove box door, then cut out part of the plastic covered up by the door, ( you wont see it once you put the door back on). Then removed blower motor and could reach up into the ducting and remove the door. I cheaped out and taped the door back in place over fresh air vent. I wasn't concerned about getting fresh air in.
To fix it correctly you will prob have to replace the electric motor that opens and closes the door and the door since it will probably have the splined end broken off.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: JDMopar]
#1875453
07/21/15 11:58 PM
07/21/15 11:58 PM
Posts: 13,585 md
mopars4ever
md
