Re: Rally wheels from Wheel Vintiques?
[Re: cudabitten]
#1872244
07/17/15 11:34 AM
07/17/15 11:34 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Summit has a mount and balance deal if you buy tires from them. One way to make sure you get a good set. I thought about buying the Mopar Cop wheels but changed my mind after reading negative reviews about air bleeding out through bad welds. Coker Tire has the Specialty Wheel made Rallys. http://www.specialtywheel.comAnd this guy does custom backspacing http://themopardude.com/New_Custom_2.html
[Re: cudabitten]
#1872435
07/17/15 06:19 PM
07/17/15 06:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I decided to go with 15 inch rally wheels for my 74 cuda, I was going to buy them through Summit, but some of the reviews were negative because of excessive run out. Anyone else have experience with these? I have several set of the Summit/Vintiques 15X7 rallyes, zero issues with run out/balance, I had them up to 140MPH, on assorted tracks/road courses, and ten of thousands of standard road miles, zero issues...they fit my 4 wheel disc equipped cars better than factory 15X7's....with the same backspacing
[Re: cudabitten]
#1872436
07/17/15 06:19 PM
07/17/15 06:19 PM
Posts: 216 E. Okla line
m88mark
E. Okla line
I decided to go with 15 inch rally wheels for my 74 cuda, I was going to buy them through Summit, but some of the reviews were negative because of excessive run out. Anyone else have experience with these? Bought Road wheels from summit about 2 years ago. One slot not punched, paint flaking at paint lines. Sent 3 back, still bad paint lines, thin chrome, rusted before I got them on the belvedere! Maybe Q/C has improved.
[Re: DAYCLONA]
#1872467
07/17/15 07:21 PM
07/17/15 07:21 PM
Posts: 4,684 Wichita
GY3
Wichita
I decided to go with 15 inch rally wheels for my 74 cuda, I was going to buy them through Summit, but some of the reviews were negative because of excessive run out. Anyone else have experience with these? I have several set of the Summit/Vintiques 15X7 rallyes, zero issues with run out/balance, I had them up to 140MPH, on assorted tracks/road courses, and ten of thousands of standard road miles, zero issues...they fit my 4 wheel disc equipped cars better than factory 15X7's....with the same backspacing I bought a pair of the 15x8 series 63 steelies and they are great! Actually put the Mickey Thompsons on them and drove around to see how out of balance they would be. They weren't! Been as fast as 128mph on the GPS and no issues whatsoever.
[Re: Twostick]
#1872670
07/18/15 12:48 AM
07/18/15 12:48 AM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Summit has a mount and balance deal if you buy tires from them. One way to make sure you get a good set. I thought about buying the Mopar Cop wheels but changed my mind after reading negative reviews about air bleeding out through bad welds. Coker Tire has the Specialty Wheel made Rallys. http://www.specialtywheel.comAnd this guy does custom backspacing http://themopardude.com/New_Custom_2.html Coker Tire owns Wheel Vintique. Kevin Coker also owns Specialty Wheels. I believe they have a Monopoly on vintage rims.
