what rear end gear oil to use #1871803
07/16/15 08:12 PM
07/16/15 08:12 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
changing the rear pot on the Cuda, what gear oil should I use,
also it bunny hops around corners(what friction modifier should I use.
Thanks Dave
Re: what rear end gear oil to use [Re: 340mouse] #1871915
07/16/15 10:13 PM
07/16/15 10:13 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
OK Let me know if this works,
80W90 2 1/2 to 3 quarts(litres up here)
GM friction modifier 1 to 2 bottles
1 bottle of Havana Club Rum (for the sore back after)
Re: what rear end gear oil to use [Re: 340mouse] #1871933
07/16/15 10:29 PM
07/16/15 10:29 PM
Kirkland, Washington
Pacnorthcuda Offline
I use 75w90. As far as the friction modifier you can't go wrong with the FORD offering at their dealerships. It's the same (or extremely similar) to what Mopar used to sell, but no longer does.
Sounds like you have a power lock (clutch type) vs. a cone type, that's good.
Re: what rear end gear oil to use [Re: Pacnorthcuda] #1871976
07/16/15 10:58 PM
07/16/15 10:58 PM
IN
ahy Offline
ahy  Offline
IN
80W90 or 75W90 sound good. I use the GM spec friction modifier from AZ with good results. One full tube.
Re: what rear end gear oil to use [Re: ahy] #1872049
07/17/15 12:21 AM
07/17/15 12:21 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Put a bottle of chrysler 4318060 additive in the dana 60 in my challenger today. Eliminated the noisy, rough feeling when turning tight curves in a parking lot.
Yeah, it's hopped up to over 160...
Re: what rear end gear oil to use [Re: 340mouse] #1872594
07/17/15 10:45 PM
07/17/15 10:45 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I think doc diff recommends 85w140 conventional with the ford FM. I used Torco RGO 85w140
But I'm sure most any fluid will be fine.
