Kickdown linkage 68 Road Runner #1871389
07/16/15 05:15 AM
07/16/15 05:15 AM
CT,USA
72CUDA340 Offline OP
CT,USA
I have a 68 road runner with a 440, I'm trying to get the car drivable it's been sitting for a few years. It needs kickdown linkage, I don't know what years and models are interchangeable? Are 440 and 383 linkage the same? Would linkage from any bigblock b-body be compatible? I'm going to try and source the linkage from a salvage yard I checked out over the weekend and if I can't find the stuff there I'll wait till the swapmeets in the fall.
Re: Kickdown linkage 68 Road Runner [Re: 72CUDA340] #1871527
07/16/15 01:10 PM
07/16/15 01:10 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
NO, you need the 440 ONLY if you are using stock kickdown...
Been there done this before with my 67 440 car....
If you look in the FSM you will see the bellcrank pictures are different..
Re: Kickdown linkage 68 Road Runner [Re: 72CUDA340] #1871651
07/16/15 04:17 PM
07/16/15 04:17 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The 440 is taller so the linkage rod that goes down from the top bellcrank to the bell crank on the side of the trans may not have enough adjustment to be used on a 440 if it's on a 383 , otherwise the other parts would be the same., that's till about 71 , after that the factory went to a one piece linkage and the 383 and 440 part would be different.
Good luck finding that stuff in a junkyard in 2015 ...
Re: Kickdown linkage 68 Road Runner [Re: JohnRR] #1871966
07/16/15 10:53 PM
07/16/15 10:53 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
John the bell crank is different, not much but slightly different..
Re: Kickdown linkage 68 Road Runner [Re: 72CUDA340] #1872532
07/17/15 08:45 PM
07/17/15 08:45 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The paddock used to sell a repop. Maybe the actual source still exists?
I want my fair share
