solid state instrument voltage regulator #1869280
07/13/15 10:35 AM
07/13/15 10:35 AM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
Anyone build there own solid state instrument voltage regulator from the old Allpar article?
http://www.allpar.com/history/mopar/electrical2.html
If so, how did you mount it?
Did it work well?
I have all the parts to build one, just looking for any tips etc.
Thanks,
Jason
Re: solid state instrument voltage regulator [Re: CUDAJAS] #1869283
07/13/15 10:45 AM
07/13/15 10:45 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's the half assed way to do it. When I built mine I installed the guts into the old mechanical regulator's housing. Using the housing itself for the heat sink.
Don't be the exception.
Re: solid state instrument voltage regulator [Re: CUDAJAS] #1870606
07/15/15 01:24 AM
07/15/15 01:24 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I've done both the external heatsink and the "in the case" conversions years ago and they held up great back in the day...With the new solid state pieces from RTE engineering not many bother to take the time and make those up anymore...
Re: solid state instrument voltage regulator [Re: CUDAJAS] #1870791
07/15/15 06:07 AM
07/15/15 06:07 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The linear regulator creates alot of heat dropping the voltage down.
When I measured my '69 gauges, each drew about 1/4-Amp at full scale, so I added a heat sink to the stock case with the regulator inside. In testing with all three gauges at full scale and without the heat sink, the regulator would start to go into thermal shutdown which limits the current output to protect the regulator. It was obvious in testing with a voltage and current meter, but from looking at the gauges, it just looks like they read lower than they should.
Re: solid state instrument voltage regulator [Re: 451Mopar] #1870832
07/15/15 11:41 AM
07/15/15 11:41 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
That was pretty much the same experience I had in doing a power supply in another project I was working on. The plastic three legged regulators were rated at 1 amp and only with a heat sink. The project drew 950 ma and even with a good heat sink, it would start shutting down. I went to a TO5 case regulator with a 3 Amp rating, problem solved. Unfortunately, they stopped making those years ago.
As a result, I did not even think about using one in the 'Cuda and went with the RTE.
Craig
Re: solid state instrument voltage regulator [Re: 451Mopar] #1870861
07/15/15 12:52 PM
07/15/15 12:52 PM
BDW Offline
BDW  Offline
My experience was the same, if you do the calculations, 1A is not enough, especially on an E-Body with 4 gauges.
Re: solid state instrument voltage regulator [Re: CUDAJAS] #1870869
07/15/15 01:04 PM
07/15/15 01:04 PM
Andrewh Online content
Andrewh  Online Content
I built my own using that article.
I got a big heat sink out of my computer parts and used thermal paste glue to stick it on.
but I only drive 2 gauges.
I have also noticed with the advent of usb chargers, you can get a pretty cheap 2 amp charger now.
if you can take one apart, you could rewire that as the vr for the gauges instead.
http://www.bhphotovideo.com/bnh/controll...=details&Q=
10 bucks. you can find them cheaper if you look.
building one was about 5 bucks.
RTE is like 25 or 35, I don't recall.
just depends on how handy you are and if you want to save a buck.
Re: solid state instrument voltage regulator [Re: CUDAJAS] #1872229
07/17/15 11:02 AM
07/17/15 11:02 AM
Owosso, Michigan
stateroadhog Offline
Owosso, Michigan
Being on this subject if the gauges are spikeing and then returning to a low reading on gauge it means the VR is going bad? Also is it true the solid state one from RTE will make gauges read lower?
Re: solid state instrument voltage regulator [Re: CUDAJAS] #1872344
07/17/15 03:12 PM
07/17/15 03:12 PM
Owosso, Michigan
Owosso, Michigan
Has anyone tried to change one mounted in car on 70 b-body?
Re: solid state instrument voltage regulator [Re: stateroadhog] #1872659
07/18/15 12:25 AM
07/18/15 12:25 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Either the regulator is going bad or there is a bad ground. On my E body, the gauges read the same as they always did.
Craig
