4l80E in a 68 Charger #1869187
07/13/15 02:19 AM
07/13/15 02:19 AM
USA
hudsonhornet7x Offline OP
USA
Can anyone tell me how much of the transmission tunnel / Torsion bar support needs cut to go into a b body? I very much like the idea of this transmission for a relatively high power build, and the electronic control options.
Thanks for any advice.
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869193
07/13/15 02:34 AM
07/13/15 02:34 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Blasphemy, of course, but I can certainly see the point. The only Mopar option is to use a 727 with a Gear Vendors OD or a 518 with an adapter and the OD unit on them is weak. But if you were to go with a 5.7 Hemi you could use one of the 8 speed truck automatics which are better than any of the GM offerings.
Back to the question...cut as much as you need to cut and as long as you are at it ditch the torsion bars for a modern suspension...there that ought to stir the wrath of the righteous faithful.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869250
07/13/15 09:08 AM
07/13/15 09:08 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
I can't tell you how much has to go, but the electronic control it offers is, as you say, very attractive. Will be interesting to see eventual info received.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869314
07/13/15 11:27 AM
07/13/15 11:27 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
I had one in a 65 Belvedere that needed the support cut out in the trans tunnel, trans mount modified and the collector on the TTI headers moved. I love it behind the a 500" motor. It was a Phoenix trans and computer and adapter. I sold the car but still have the trans set up and 500" that will be going in another 65 Coronet. The best part about it is you can set the shift points and the trans would shift itself bracket racing. It was considered No E because all the new cars use the same computer.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869315
07/13/15 11:27 AM
07/13/15 11:27 AM
USA
USA
I would love to run the NAG1 but it doesn't look like there are controllers to make the swap worth it. THe 4l80E has the controller.
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869339
07/13/15 12:05 PM
07/13/15 12:05 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
friend of mine has one behind a bb cheby, its been in the 8's and is street driven all the time. never had one issue with it. I think it was a art carr build. easy 500 passes on it. they are tough
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869394
07/13/15 02:11 PM
07/13/15 02:11 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Run it, its a TH400 with OD, very stout.
Mopar to the bone!!!
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869424
07/13/15 03:06 PM
07/13/15 03:06 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
NAG1 controllers are available but the trans aren't nearly as popular in junkyards around my area. They seem to be smaller and lighter.
http://soundgermanautomotive.com/pcs/
I've got a 4l80e and wilcap sb adapter that will be going in my Duster with a megasquirt based trans controller.
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869432
07/13/15 03:15 PM
07/13/15 03:15 PM
USA
USA
Have you figured how much cutting you will need to do to put it in your duster?
Re: 4l80E in a 68 Charger [Re: 65 Hemi] #1869449
07/13/15 03:42 PM
07/13/15 03:42 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I love it!!! Another pioneer not afraid to think outside the "Mopar or No Good" Box up
2008 Honda Element
Re: 4l80E in a 68 Charger [Re: hudsonhornet7x] #1869453
07/13/15 03:51 PM
07/13/15 03:51 PM
Woodstock, IL
TurboMike Offline
TurboMike  Offline
Woodstock, IL
I have no experiance with shoe horning any of these trannys into a Mopar, but I can tell you a 4l60 is smaller, lighter, has a ton of aftermarket support, and the bellhousing unbolts from the case. There are a couple of manufacturers that have Mopar bolt pattern ones out there, big and smallblock. Mike
Re: 4l80E in a 68 Charger [Re: Polarapete] #1869979
07/14/15 04:17 AM
07/14/15 04:17 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Yeah, Im pretty messed up. I also run 9" stuff in 4 of my cars and enjoy the ease of swapping the different 3rd members. When mopar guys start hassling me about a ford rear end I ask them to find a ford part on it. The only Ford part is the bolt pattern.
Doug
MOPAR or NO CAR!!!
