Re: Brake Pull Issue
[Re: floorit426]
#1868823
07/12/15 03:23 PM
07/12/15 03:23 PM
RapidRobert
The car has a pull to the right initially when you hit the brakes. I am not sure what the next step should be. Could this be a suspension problem? not a susp prob. for some reason the Dr front side ain't doing its job. Both sides/shoes have to apply at the same time. first thing to check/do is spoon up those dr side front shoes. I crank it up till the wheel is locked then back off till as I spin the wheel FORWARD I can just hear a slight "tick" at one point of the tires' revolution. not a drag that slows it just listen for that tick. likely you will go past free then come back up to the tick.
[Re: RapidRobert]
#1868868
07/12/15 04:50 PM
07/12/15 04:50 PM
Posts: 15,487 Omaha Ne
TJP
Omaha Ne
The car has a pull to the right initially when you hit the brakes. I am not sure what the next step should be. Could this be a suspension problem? not a susp prob. for some reason the Dr front side ain't doing its job. Both sides/shoes have to apply at the same time. first thing to check/do is spoon up those dr side front shoes. I crank it up till the wheel is locked then back off till as I spin the wheel FORWARD I can just hear a slight "tick" at one point of the tires' revolution. not a drag that slows it just listen for that tick. likely you will go past free then come back up to the tick. I'll politely disagree, it could very well be a suspension or frame problem. Think loose tie rod ends, idler pitman, ball joints worn out bushings etc. Less likely is a frame related issue but possible. had a 56 Ford in several years ago with a R brake pull that several shops had looked at. They failed to notice the front suspension cross member was rotted 3/4 of the way around.
[Re: floorit426]
#1868922
07/12/15 06:43 PM
07/12/15 06:43 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The left brake is not working as well as the right. Could be hose, caliper, etc.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: floorit426]
#1869160
07/13/15 01:25 AM
07/13/15 01:25 AM
HemiRick
Memphis
Yes pretty much eliminates the brakes, sounds like a bad control arm bushing.
