how much fluid goes into a torque converter?
#1868280
07/11/15 04:19 PM
07/11/15 04:19 PM
Posts: 610 Hamilton, Ont, Canada
Dart_it_All
getting ready to reinstall the motor and tranny in my 67 cuda after many years.
My question is how much tranny fluid do I put into the torque converter? it has been moved around a few time and lost fluid. I will be draining the old fluid.
Thanks Robin
Father of 1969 Dart Custom, 318 4bbl, 904, 8 1/4 rear soon to be a 340 1967 Barracuda, 273 Commando, 4bbl, 904, 7 1/4 rear Project car
Re: how much fluid goes into a torque converter?
[Re: Dart_it_All]
#1868298
07/11/15 04:54 PM
07/11/15 04:54 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You won't be able to fill the converter before installation. Pour one quart into it and allow the pump to fill the converter by starting in Neutral.
If the trans hasn't been touched, a new front seal would be wise.
[Re: Dart_it_All]
#1868523
07/11/15 11:52 PM
07/11/15 11:52 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Totally depends on what size converter you run. Mine is a 9" and I believe I got 2 qts in it. You can set it upright and tip it back to a out 75 degrees and fill it till it won't take any more, then tip it to 91 degrees and let it drain a little in a catch can.
I’m listening.
[Re: Big Bad Bee]
#1868731
07/12/15 12:30 PM
07/12/15 12:30 PM
Dart_it_All
