I have a 2005 Cummins Ram, & a few weeks ago after buying fuel at a new station the engine began to "blurble" at start up, as though it had water. So I opened the water drain valve, but that had no effect, did it numerous times with no luck. tried various additives & injector cleaners & at first it got better, then started again. Recently replaced the fuel filter with a new Baldwin (which I had previously done back in the winter, btw) but still no improvement. After the engine runs a few seconds it comes out of it, after I've opened the throttle. But it's annoying plus I don't want anything getting worse. What am I overlooking? Oh, and since that time it's had several fills of presumably top quality Shell diesel.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin
www.wwnboa.org if you're interested in '62-'74 B-Bodies
