Re: In-line Hemi Carbs & Linkages
[Re: JohnRR]
#18676
11/29/05 05:24 PM
11/29/05 05:24 PM
Check out SHAKERHOOD.COM He has air horn adapters and also the new base plates for the new dual inline intakes.Carbs are spaced alittle more apart from the org. stuff.Give him a call if still have questions.He has what you need or can hook you up!
#18677
11/29/05 06:45 PM
11/29/05 06:45 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
yes i know that ben has baseplates , but WHAT ABOUT A LID TO GO WITH THAT BASEPLATE ???
[Re: JohnRR]
#18678
11/29/05 10:13 PM
11/29/05 10:13 PM
He (Ben)would be the one to ask.I know that I would not cut any org. base again.I have a six pack on ebag right now.The base plate I had cut years back for racing.Had a guy tell me it was worth 2,000.00 befor I chopped on it.That it was off a 69 1/2 Superbee/Roadrunner, lift off hood car.
[Re: JohnRR]
#18682
11/29/05 11:07 PM
11/29/05 11:07 PM
Posts: 657 Berlin NJ
scottk
Berlin NJ
John. I fabbed a bracket that bolts down to the carbs and has an offset stud that lines up so you can use a six pack lid. Works well. Let me know if you want me to post a pic.
#18684
11/30/05 12:36 AM
11/30/05 12:36 AM
JohnRR
hey its just a part , if we were as greedy then as we are now we would have done nothing but buy them and put them in storage in a zip lock baggie ...
oh i have one of those 2k air cleaners , i'm thinking of making it fit my hemi s new dual quad setup and putting a fiberglass lift off hood on my bee ... seriously ...
[Re: rrrttt]
#18686
11/30/05 01:15 AM
11/30/05 01:15 AM
DID YOU CHECK HERE?
Check with Classic Haulage in Canada. He advertises in MCG and makes a lot of different Hemi bases.
He also makes aluminum tops that look like the original 66-68 but they fit the Edel. carbs, he may make other tops as well.
#18687
11/30/05 01:18 AM
11/30/05 01:18 AM
JohnRR
DID YOU CHECK HERE?
no not yet , i know they do the non fresh air stuff , but fresh air setups ???
[Re: JohnRR]
#18689
12/02/05 01:33 PM
12/02/05 01:33 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
That's what I want.. A "correct appearing" fresh air setup Of course if I had a non fresh air car, all that would be available is the fresh air stuff
[Re: CRE2004]
#18690
12/02/05 03:44 PM
12/02/05 03:44 PM
JohnRR
[Re: JohnRR]
#18691
12/06/05 10:29 AM
12/06/05 10:29 AM
Posts: 4,687 VA
69 Road Runner
VA
I just spoke with Tim Banning of For Hemis Only. He makes the baseplate for the Stage V with dual Eddy carbs. He also makes a Six Pack lid and has an offset stud for the rear carb that makes everything line up. You can buy everything from him. I thought the Six Pack and Hemi lids were the same, but I guess they're different. If you have an original Hemi lid, or buy a reproduction Hemi lid (also available from www.forhemisonly.com), Tim has a guy who makes an adapter for the carb studs that works with the Hemi lid. The price for that pieces isn't too hateful considering it's a "Hemi" part.
69 Road Runner Vert
