Page 3 of 3 1 2 3
Re: In-line Hemi Carbs & Linkages [Re: JohnRR] #18676
11/29/05 05:24 PM
11/29/05 05:24 PM
Check out SHAKERHOOD.COM He has air horn adapters and also the new base plates for the new dual inline intakes.Carbs are spaced alittle more apart from the org. stuff.Give him a call if still have questions.He has what you need or can hook you up!
Re: In-line Hemi Carbs & Linkages #18677
11/29/05 06:45 PM
11/29/05 06:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes i know that ben has baseplates , but WHAT ABOUT A LID TO GO WITH THAT BASEPLATE ???
Re: In-line Hemi Carbs & Linkages [Re: JohnRR] #18678
11/29/05 10:13 PM
11/29/05 10:13 PM
He (Ben)would be the one to ask.I know that I would not cut any org. base again.I have a six pack on ebag right now.The base plate I had cut years back for racing.Had a guy tell me it was worth 2,000.00 befor I chopped on it.That it was off a 69 1/2 Superbee/Roadrunner, lift off hood car.
Re: In-line Hemi Carbs & Linkages [Re: JohnRR] #18679
11/29/05 10:17 PM
11/29/05 10:17 PM
VA
69 Road Runner Offline
VA
http://www.forhemisonly.com/new%20products%20baseplate.html
Add the MP air grabber oval lid, K&N or Fram filter element, and you're good to go.
i've seen that , but the carb studs are farther apart so i astock lid won't work
Give Tim Banning a call about it. I was under the impression that he could make it work. At least I hope so. I'm having him build a Hemi for me.
69 Road Runner Vert
Re: In-line Hemi Carbs & Linkages [Re: JohnRR] #18680
11/29/05 10:23 PM
11/29/05 10:23 PM
VA
VA
If it doesn't work, could you fill in the holes on the reproduction lid, drill correctly spaced ones, and then repaint?
69 Road Runner Vert
Re: In-line Hemi Carbs & Linkages [Re: 69 Road Runner] #18681
11/29/05 10:44 PM
11/29/05 10:44 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Could you bend and make offset air cleaner studs?
Re: In-line Hemi Carbs & Linkages [Re: JohnRR] #18682
11/29/05 11:07 PM
11/29/05 11:07 PM
Berlin NJ
scottk Offline
scottk  Offline
Berlin NJ
John. I fabbed a bracket that bolts down to the carbs and has an offset stud that lines up so you can use a six pack lid. Works well. Let me know if you want me to post a pic.
Re: In-line Hemi Carbs & Linkages [Re: scottk] #18683
11/29/05 11:19 PM
11/29/05 11:19 PM
VA
VA
Yes, please post pics!
69 Road Runner Vert
Re: In-line Hemi Carbs & Linkages #18684
11/30/05 12:36 AM
11/30/05 12:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
hey its just a part , if we were as greedy then as we are now we would have done nothing but buy them and put them in storage in a zip lock baggie ...
oh i have one of those 2k air cleaners , i'm thinking of making it fit my hemi s new dual quad setup and putting a fiberglass lift off hood on my bee ... seriously ...
Re: In-line Hemi Carbs & Linkages [Re: scottk] #18685
11/30/05 12:39 AM
11/30/05 12:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i could bend stuff up , but i'm so busy i'd never get it done
what we need is ben to come clean on the REPOP A12 air clearns and make one that fits the stage 5 carb spacing for use with a lift off hood for under a G .
yes , pics please ...
Re: In-line Hemi Carbs & Linkages [Re: rrrttt] #18686
11/30/05 01:15 AM
11/30/05 01:15 AM
DID YOU CHECK HERE?
Check with Classic Haulage in Canada. He advertises in MCG and makes a lot of different Hemi bases.
He also makes aluminum tops that look like the original 66-68 but they fit the Edel. carbs, he may make other tops as well.
Re: In-line Hemi Carbs & Linkages #18687
11/30/05 01:18 AM
11/30/05 01:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
DID YOU CHECK HERE?
no not yet , i know they do the non fresh air stuff , but fresh air setups ???
Re: In-line Hemi Carbs & Linkages [Re: JohnRR] #18688
12/02/05 12:05 PM
12/02/05 12:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
scott k , wheres those pics
Re: In-line Hemi Carbs & Linkages [Re: JohnRR] #18689
12/02/05 01:33 PM
12/02/05 01:33 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
That's what I want.. A "correct appearing" fresh air setup Of course if I had a non fresh air car, all that would be available is the fresh air stuff
Re: In-line Hemi Carbs & Linkages [Re: CRE2004] #18690
12/02/05 03:44 PM
12/02/05 03:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: In-line Hemi Carbs & Linkages [Re: JohnRR] #18691
12/06/05 10:29 AM
12/06/05 10:29 AM
VA
VA
I just spoke with Tim Banning of For Hemis Only. He makes the baseplate for the Stage V with dual Eddy carbs. He also makes a Six Pack lid and has an offset stud for the rear carb that makes everything line up. You can buy everything from him.
I thought the Six Pack and Hemi lids were the same, but I guess they're different. If you have an original Hemi lid, or buy a reproduction Hemi lid (also available from www.forhemisonly.com), Tim has a guy who makes an adapter for the carb studs that works with the Hemi lid. The price for that pieces isn't too hateful considering it's a "Hemi" part.
69 Road Runner Vert
Re: In-line Hemi Carbs & Linkages [Re: 69 Road Runner] #18692
12/06/05 10:44 AM
12/06/05 10:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
cool , i'll have to give him a ring ...
Page 3 of 3 1 2 3
