Re: 440 Oil Priming, 25psi
[Re: jlatessa]
#1867711
07/10/15 01:48 PM
07/10/15 01:48 PM
dogdays
An oil pump is a constant volume pump, meaning it puts out a certain volume of liquid for every revolution. Oil pressure builds when the pump's output is higher than will leak out of the engine's many leaks at a low pressure. It's really very simple. If your drill is spinning the oil pump shaft at 600rpm the oil pressure should replicate cold oil pressure at 1200 engine rpm.
As you prime the system with your drill, at some point the pressure builds high enough that the drill can't spin the pump any faster. It depends on the drill power, the pump size and the amount of the leaks in the engine. Starting from oil pickup tube empty, it should feel like at some point the drill bogs down.
That's all you really need to see. You're not performing diagnostics, you're simply making sure all the oil passages are full before you start the engine. The thing to watch out for is when you start from zero and the drill fills the lines BUT DOESN'T BOG DOWN. This is a clue that your oil pump has a problem, or else that you have a really big leak in the engine.
In my case it meant the oil pump I had installed had a problem. 10,000 miles later I got to take the engine apart again.
R.
[Re: CoDart]
#1867749
07/10/15 02:49 PM
07/10/15 02:49 PM
Posts: 43,240 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#1867808
07/10/15 05:18 PM
07/10/15 05:18 PM
RapidRobert
agreed 7/16" is too much & I like to have it touching to avoid stress cracking from it hanging suspended over time (I add spacers on the circumference so it is touching & still have ~1/8" at least (depends on RPM range/oil mods). What Cab said you should have way more than 25 & even with that distance with no slosh on a stand it wouldn't be sucking air to cause a low reading (if in doubt toss in another 2 qts just for a test, you can drain that amt when done). Holler how it goes/turns out.
[Re: RapidRobert]
#1867849
07/10/15 07:14 PM
07/10/15 07:14 PM
dogdays
You guys are overthinking this one. A drill will pull down to a fraction of its rated speed if presented with a decent load, and no-one can really tell how fast it's going. I repeat, the main reason to spin the pump is to fill all the oil passages with oil before startup. AND, many many many engines are started up without this step and live just fine.
The guy getting 25 psi should thank his lucky stars and move on to other things that need more attention. For the kind of question asked, plus the information he gave about clearances, things are OK. At 10 lb per thousand rpm, his engine could be turning 2500rpm and that'd still be OK.
As there isn't a problem, any the effort trying to "figure it out" is wasted.
In my case I didn't have an oil pressure gauge and the fact that the drill DIDN'T pull down should have been an indication that something wasn't right. In my hubris I ignored that fact, and paid for it later.
If everyone who was starting out building an engine were to read all the warnings and fulminations on this board, the entire population of gearheads would quit the hobby and take up knitting.
It's not brain surgery.
R.
[Re: dogdays]
#1868069
07/11/15 01:58 AM
07/11/15 01:58 AM
RapidRobert
Well, what Dog said we might be OCD ing this. Ori what I'd do (in order/as needed if the prior one dont help) is (1) have a known correct gauge (2) grab a fast(er) drill (3) toss in 2 more qts & see what you see. 25 just seems low
[Re: shorthorse]
#1868192
07/11/15 12:44 PM
07/11/15 12:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Please don't take this wrong but is the drill turning in the right direction? You get no oil pressure turning it the wrong way.
[Re: CoDart]
#1868357
07/11/15 06:42 PM
07/11/15 06:42 PM
Supercuda
About to go away
About to go away
up yours
What is the clearance between the lifters and the lifter bores? Might be too loose, in which case it's a problem.
[Re: CoDart]
#1868444
07/11/15 09:58 PM
07/11/15 09:58 PM
Posts: 3,916 usa
lewtot184
usa
Yes all 4 galley are plugged. Sealant tape as well.
The lifters do have a tiny hole from the galley which feeds on top of the roller. Is this okay to run like this? call whoever's tappets you have. you may have a small base circle on the camshaft letting the tappets drop down to far,....? you won't solve this on this website.
[Re: CoDart]
#1868458
07/11/15 10:20 PM
07/11/15 10:20 PM
Cab_Burge
Get someone to help you test this, prime the motor while slowly turning the crankshaft through two full revolutions and watch the oil presure If it changes for the better, higher pressure, your lifters are exposing the lifter main oil galleys on one side or the other when rotating it If that is the case you will need to change the lifters to a taller body type lifter that won't expose the oil galleys or have the lifter holes bushed. I had one 426 Street Hemi motor that I had to block the oil off to the left(drivers side) lifter gallery due to the solid roller lifters on that side exposeing lifter oil galley at max lift, the right side was fine Do not run the motor with 25lbs cold oil pressure Figure out what the problem is and fix it IHTHs I primed a motor last week with hydraulic lifters, it flowed a lot of oil out the sides of them also, it did have over 70 lbs oil pressure cold when priming it with a 1/2 drill motor at 400+ RPM with 10W30 Wt oil in it
