Best online source for engine bearings #1867281
07/09/15 05:07 PM
07/09/15 05:07 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Looking for the best website for selection and price. BBM if it matters. thanks
Re: Best online source for engine bearings [Re: varunner] #1867285
07/09/15 05:12 PM
07/09/15 05:12 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Check Amazon and even e bay. I bought my Kings from summit, the mains were a little tight to suit me so I bought a set of 1 overs off e bay.
Re: Best online source for engine bearings [Re: varunner] #1867293
07/09/15 05:22 PM
07/09/15 05:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Summit or jegs , if there is an issue easy to return ... the bad is you may get a set someone opened then returned , the bearings flailing around in the box on multiple shipments beats them up ... return them for another set , tell summit the real reason so they hopefully will toss them instead of sending them to someone else .
Re: Best online source for engine bearings [Re: varunner] #1867361
07/09/15 07:50 PM
07/09/15 07:50 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I should have mentioned it's for a low deck 383. I'd like to find a coated, full groove standard width bearing. Race only, stock crank, so very little if any radius on the journals.
Re: Best online source for engine bearings [Re: varunner] #1867405
07/09/15 09:42 PM
07/09/15 09:42 PM
Fresno CA.
cortsGTS Offline
cortsGTS  Offline
Fresno CA.
Hughes Engines
Re: Best online source for engine bearings [Re: varunner] #1867467
07/09/15 11:43 PM
07/09/15 11:43 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Ben at Promax in Indy, he's a good guy
Re: Best online source for engine bearings [Re: varunner] #1867488
07/10/15 12:04 AM
07/10/15 12:04 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Hughes has calico coated bearings by acl. Thinking about getting these for by build as well.
Re: Best online source for engine bearings [Re: FastmOp] #1867683
07/10/15 12:52 PM
07/10/15 12:52 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
He is a crock ! rip me off !! Would not give him a penny !
Liar also.
Re: Best online source for engine bearings [Re: varunner] #1867704
07/10/15 01:31 PM
07/10/15 01:31 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I bought a lot of stuff from him, and will do so again.
Your results may very lol
Re: Best online source for engine bearings [Re: VernMotor] #1868037
07/11/15 01:04 AM
07/11/15 01:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Summit... plenty of brands and good prices... IF you had
to send them back for what ever reason.. that no problem
wave
Re: Best online source for engine bearings [Re: varunner] #1868039
07/11/15 01:07 AM
07/11/15 01:07 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Check the prices at 440 source also. The had the best price on piston rings when I was checking, but I bought coated bearings from Summit Racing.
Re: Best online source for engine bearings [Re: varunner] #1868144
07/11/15 09:39 AM
07/11/15 09:39 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
440 source has a good write-up on bearings as well. I didn't see a whole lot on summits website, I'll probably give them a call. Knowing what sizes are available in the type I want is the first step. I first need to pick them out, then after the crank is ground I'll buy them.
