brake experts question for you
#1867375
07/09/15 08:28 PM
07/09/15 08:28 PM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
did a 68 charger for a guy. They put a kit on the front disc brake kit from I believe it was primoclassics on here I bet over 8+ years ago. It was suppose to be a factory replacement kit with everything from master cylinder to spindles and all other parts. It assembled good. He also wanted rear disc brakes on the car so we bought a kit from speedway motors that welded the caliper brackets on and mounted the brakes. A friend put them on his pro street dart and they worked out great. Well car has never had solid feeling brakes and now hes complaining that even with line lock on all it does is slides the front wheels. They don't hold and will slightly roll forward while applying the brakes and gas. Not solid enough. Any ideas? Car doesn't get driven a lot but he wants good brake naturally. Car is a 440 auto car. Could it be not enough vacuum? Or portioning valve issue? would an adjustable one work? If so who makes the best?
Contact Me about AMD Prices
Re: brake experts question for you
[Re: stumpy]
#1867759
07/10/15 03:10 PM
07/10/15 03:10 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If it's sliding the front wheels then it is doing what it should and he needs to back of the gas. Or get beefier front tires.
[Re: hotairballoonpilot]
#1867818
07/10/15 05:28 PM
07/10/15 05:28 PM
RapidRobert
I'm hearin that it ain't been right since day 1. I'd (1) set the pushrod clearance to ~.020 (2) take off the MC lines & cap the MC ports with a pair of brass male inverted flare plugs from the Edelman cabinet at your parts house (they're cheap & you will reuse em in the future) (3) eng idling, if the MC is good & bled out & booster functioning, the pedal should be rock hard with virtually no travel. that'd be a start (& the MC/booster is the beginning)
