04 dakota engine swap #1866746
07/08/15 05:26 PM
07/08/15 05:26 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
how much trouble would it be to swap my dead 3.7 for a 318 with 904 tranny?
Re: 04 dakota engine swap [Re: PLMCRZY] #1866800
07/08/15 06:52 PM
07/08/15 06:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You need a 03 5.9 donor dakota for mounts, fuel lines, harness, computer, a 904, a new driveshaft (or two if 4x4), you will have to fab the trans mount and you will need a 318 magnum, if you are talking a 318 LA than you will be doing a ton of wiring and fighting with computer systems. If you have a grey ignition key your job gets even harder either way.
Re: 04 dakota engine swap [Re: HotRodDave] #1866811
07/08/15 07:15 PM
07/08/15 07:15 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
key is not grey, but what is it?
Re: 04 dakota engine swap [Re: PLMCRZY] #1866847
07/08/15 08:18 PM
07/08/15 08:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The grey key means it has a security system and you have to keep all the computers together with it. A Plain metal or black key is the one you want, then the engine computer for an 03 5.9 computer without security will run a 318 magnum.
Re: 04 dakota engine swap [Re: PLMCRZY] #1866932
07/08/15 10:11 PM
07/08/15 10:11 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
thanks for great info. can you recommend any websites or people that have done similar swaps?
Re: 04 dakota engine swap [Re: PLMCRZY] #1867248
07/09/15 03:42 PM
07/09/15 03:42 PM
dogdays Offline
dogdays  Offline
I'm going to guess that by the time you get your halfbreed running you'll wish you'd just found another 3.7. The compatibility issues are pretty large in my estimation.
R.
Re: 04 dakota engine swap [Re: PLMCRZY] #1867249
07/09/15 03:44 PM
07/09/15 03:44 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I don't know of any, just what I have learned on my own. Most people end up putting a used 3.7-4.7 back in and selling it when the costs are added up. You can buy a nice 5.2 5.9 truck for less than the swap. If you decide to do it though I Have a ton of parts I could sell to help you out.
Re: 04 dakota engine swap [Re: PLMCRZY] #1867354
07/09/15 07:45 PM
07/09/15 07:45 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
dogdays is probably right, might just part it out. unless i can find a good low mileage replacement. doesn't the replacement have to be the same year?
