How to Determine the Correct Speedometer Gears? #1866561
07/08/15 02:00 PM
07/08/15 02:00 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Hello all!
I have to throw this out there as I'm not having any luck in finding out the correct speedometer gear for my application.
Here's what I am working with.
Trans: A833 4-spd
Dana rear: 3.54:1
Tires: P245/60R14
Any information as always is greatly appreciated.
Thanks!
Re: How to Determine the Correct Speedometer Gears? [Re: kz5rt2] #1866571
07/08/15 02:18 PM
07/08/15 02:18 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
the chart is located in the tech archive section.
http://www.moparts.org/Tech/tech/pages/speedo.html
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: How to Determine the Correct Speedometer Gears? [Re: kz5rt2] #1866582
07/08/15 02:25 PM
07/08/15 02:25 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
An old rule of thumb is each tooth is worth 2mph.
Carl Kessel
Re: How to Determine the Correct Speedometer Gears? [Re: CKessel] #1866596
07/08/15 02:49 PM
07/08/15 02:49 PM
in a parking lot make a paint mark in the middle of the tread at ~8 O'clock then roll the car forward straight ahead (~8 ft) till it leaves another mark & tape measure that distance (rollout) then divide Pi (3.14) into that number to get the exact dia then go to the archives chart along with your gear ratio (locate the chart that goes down to the tenths of an inch IE 26.2. jack up the car way high on the dr side to minimize fluid loss & be sure to clock the adapter on the side of the trans correctly for the number of teeth pinion you will be using.
Re: How to Determine the Correct Speedometer Gears? [Re: kz5rt2] #1866610
07/08/15 03:01 PM
07/08/15 03:01 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Thank you very much!
Re: How to Determine the Correct Speedometer Gears? [Re: kz5rt2] #1866619
07/08/15 03:07 PM
07/08/15 03:07 PM
BDW Offline
BDW  Offline
Re: How to Determine the Correct Speedometer Gears? [Re: BDW] #1866625
07/08/15 03:13 PM
07/08/15 03:13 PM
that be the one!
