Re: howards cam
[Re: ragin sonny]
#1866644
07/08/15 03:30 PM
07/08/15 03:30 PM
Challenger 1
Cincinnati, Ohio
my friend bought mild hyd cam&lifters for his 440 from summit.one lifter nib had half of the plunger missing! where's the quality control? they replaced the lifter,then on fire up, it ran 5 minutes and sheared the dowel pin in the cam! no way that's his fault! Chinese junk or what? How could it shear the dowel pin if the bolt was torqued properly?
Re: howards cam
[Re: ragin sonny]
#1866659
07/08/15 03:53 PM
07/08/15 03:53 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
The cam my be too tight in the block, maybe a burr or poorly machined timing set and even if it were torqued to spec the gear may not fit the cam properly. Looks like the OP changed his post Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: howards cam
[Re: ragin sonny]
#1866675
07/08/15 04:08 PM
07/08/15 04:08 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I too will add I HIGHLY doubt this is a Howards cam issue. I have used their stuff for years, and a sheared pin doesn't " just happen". Professional or not, there is something else that caused it.
As far as the lifters, they buy them from another manufacture, and someone apparently dropped the ball in shipping I would have to assume.
I think your post is a little premature on the Howards bashing.
RIP Monte Smith
Re: howards cam
[Re: ragin sonny]
#1866774
07/08/15 06:05 PM
07/08/15 06:05 PM
CompWedgeEngines
Syracuse,NY
All good. Howard's are good people,and do as much USA product as they can.
Just take a good look at that timing set fitment etc. As stated, the only way the dowels break,are if something else suddenly stops or goes solid,the bolt is loose,or maybe.the bolt was too long and bottoming out in the cam before it tightened?
RIP Monte Smith
