Re: Hot electronic voltage regulator when key left on
[Re: sawdust]
#1866356
07/08/15 02:56 AM
07/08/15 02:56 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Bad stuff happens to ignition systems, too, when you leave the key in the "run" position while the engine is not running. So don't do it. If you need to trace some circuit, use a VOM or powered circuit tester.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: sawdust]
#1866359
07/08/15 02:58 AM
07/08/15 02:58 AM
RapidRobert
It'd be getting hot from "full fielding" the field circuit to raise the system voltage to what the reg is built for which ain't working since the alt ain't charging/raising up the system voltage even with the reg constantly grounding the green field wire to max it out. reg is flowing max current
