727 drop down linkage replacement #1865862
07/07/15 02:13 PM
07/07/15 02:13 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
With my current three piece drop down linkage on my 727, I cannot get WOT with the linkage set at the proper shift points. I am looking for alternatives to using this setup. Thanks, any help will work
Re: 727 drop down linkage replacement [Re: JL2] #1865898
07/07/15 03:19 PM
07/07/15 03:19 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Picture ?
Re: 727 drop down linkage replacement [Re: JL2] #1865909
07/07/15 03:32 PM
07/07/15 03:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Factory carb or aftermarket? If aftermarket does it have the correct Mopar throttle lever extension?
In many cases, shift points that are comfortable to an individual aren't correct by the book.
Re: 727 drop down linkage replacement [Re: John_Kunkel] #1865992
07/07/15 06:14 PM
07/07/15 06:14 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
I'm running a HOLLEY 750.
Re: 727 drop down linkage replacement [Re: JL2] #1865995
07/07/15 06:22 PM
07/07/15 06:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does it have the correct 20-7 Mopar throttle lever extension? Without it you'll never get the linkage to work correctly.
http://www.summitracing.com/parts/hly-20-7?seid=srese1&gclid=CKWbysPsycYCFchffgodwgYLSg
Re: 727 drop down linkage replacement [Re: JL2] #1866008
07/07/15 06:43 PM
07/07/15 06:43 PM
BDW Online content
BDW  Online Content
Re: 727 drop down linkage replacement [Re: JL2] #1866279
07/08/15 12:36 AM
07/08/15 12:36 AM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Ditched all my linkage and went with Bouchllon cable. Made life simple.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 727 drop down linkage replacement [Re: JL2] #1866642
07/08/15 03:28 PM
07/08/15 03:28 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
Thanks guys, I will check it out,
Re: 727 drop down linkage replacement [Re: JL2] #1866861
07/08/15 08:46 PM
07/08/15 08:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If you cannot get the factory three piece linkage to work, you're likely doing something wrong.
