BB oil pan depths #1859905
06/29/15 08:08 PM
06/29/15 08:08 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Anyone have the actual depths of stock big block oil pans (both standard and hemi)? Pan rail to bottom of sump.
Thanks,
Re: BB oil pan depths [Re: Stanton] #1860010
06/29/15 10:06 PM
06/29/15 10:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Which standard and which hemi ?
Re: BB oil pan depths [Re: Stanton] #1860089
06/29/15 11:46 PM
06/29/15 11:46 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
'68/69 ... b-body ... Plymouth
Re: BB oil pan depths [Re: Stanton] #1860128
06/30/15 12:24 AM
06/30/15 12:24 AM
IN
ahy Offline
ahy  Offline
IN
Round numbers, I believe the "car" pan is 4 1/2" and the Hemi pan is 5 1/2".
At least the difference was enough that my '70E benefited from a K mounted skid plate to protect the re-pop Hemi pan... skid plate has earned its keep.
Re: BB oil pan depths [Re: Stanton] #1860392
06/30/15 11:47 AM
06/30/15 11:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Which Hemi pan do you want to use , the 66-69 is deeper than the 70-71 ...
I have all the pans at home, I didn't get back on line last night.
Though I MIGHT have something here at work ???
Re: BB oil pan depths [Re: Stanton] #1860398
06/30/15 11:52 AM
06/30/15 11:52 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I'm fabbing a K-member and made a jig with the stock b-body K. I want to make sure its low enough to protect a road race pan but didn't have a stock pan to compare it to for depth. So ideally I need the depth of a standard b-body, b-motor pan for comparison.
Re: BB oil pan depths [Re: Stanton] #1860414
06/30/15 12:05 PM
06/30/15 12:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ok , got it , the Hemi pan for 69 hangs below the K , I think I have a 402 pan here ...
Re: BB oil pan depths [Re: Stanton] #1860487
06/30/15 01:36 PM
06/30/15 01:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The front of the sump of the 402 is 4.5" , it is ABOVE the bottom of the K frame .
A 70-71 hemi in my experience is LEVEL with bottom of K, I don't have it handy to measure.
Re: BB oil pan depths [Re: Stanton] #1862450
07/02/15 11:30 PM
07/02/15 11:30 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
John RR - you need to clean out your inbox ... can't send you a PM
So I'm thinking that rather than mess around trying to figure pan depths, it might be easier to know how far the engine pan rail is above the K at the front of the block. Can anyone measure that and let me know.
Much appreciated !!
Re: BB oil pan depths [Re: Stanton] #1864800
07/06/15 12:36 AM
07/06/15 12:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Much appreciated !!
The board change added over 1000 PM's to my box , it's going to be a while before I get them cleaned out ...
I will get over to a friends in the next couple of days and get that, he has a 69 B body with 402 pan that is the easiest for me to get to .
Re: BB oil pan depths [Re: Stanton] #1864836
07/06/15 01:20 AM
07/06/15 01:20 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
oil pans
TRY THIS LINK
Re: BB oil pan depths [Re: JohnRR] #1864971
07/06/15 11:46 AM
07/06/15 11:46 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
If you can, just measure from the pan rail on the block to the K. I'm heading to Carlisle so can probably do it there but you can imagine what might happen if I crawl under some guys car with a tape measure !!
Re: BB oil pan depths [Re: Stanton] #1865000
07/06/15 12:28 PM
07/06/15 12:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bottom of the K I assume, should be able to do it tonight .
Re: BB oil pan depths [Re: JohnRR] #1865151
07/06/15 03:46 PM
07/06/15 03:46 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Bottom or top - just tell me where!
Re: BB oil pan depths [Re: Stanton] #1867194
07/09/15 01:54 PM
07/09/15 01:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Not sure if you'll see this from Carlisle but I measured from the pan rail on the block straight down to the K frame and it was about 4.75 , maybe 4.875 .
Not sure if the K goes a little lower from that point towards the center? The 402 pan looked ALMOST flush with the bottom of the K , it has 2 Fel pro black gaskets and a stock mopar Windage tray.
Re: BB oil pan depths [Re: Stanton] #1868421
07/11/15 08:47 PM
07/11/15 08:47 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Thanks. I crawled under a car at Carlisle and got roughly the same measurements.
