Comp Rockers or Crane Rockers #186465
01/07/09 09:08 AM
01/07/09 09:08 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I would like to upgrade my stock rockers from my 440 to an adjustable roller rocker. I have a smaller .480 lift cam, so I am going to use a 1.6 ratio. I have heard Crane rockers are the best for the buck vs. cheap ones that will just break or expensive ones that I do not need. How about Comp rockers though? Do they have the same quality as Crane? or.. Thanks.
RS23L7 4-Speed
Re: Comp Rockers or Crane Rockers [Re: Mopar_Mike] #186466
01/07/09 09:17 AM
01/07/09 09:17 AM
The crane units are fine on small cams up to .620..I have not used the comps...I would buy Harland Sharp rockers if it was mee.. They will work on bigger cams if you ever decide to upgrade..
poppaj
Re: Comp Rockers or Crane Rockers #186467
01/07/09 11:55 AM
01/07/09 11:55 AM
poppaj
i have to agree. in most cases the Harland Sharp rockers arent that much more money and you'll have somthing that will handle just about anything you can throw at them. if you need pricing, please contact me.
Re: Comp Rockers or Crane Rockers [Re: Mopar_Mike] #186468
01/07/09 12:05 PM
01/07/09 12:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
For that cam why spend the extra $$ for a roller cam. They will provide no power gain over a good doctile rocker giving a slightly closer ratio. The gain recieved by using a roller in large cams come from helping to prevent side loading. Here is a quote from Dulcich on the subject.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Comp Rockers or Crane Rockers [Re: Mopar_Mike] #186469
01/07/09 12:18 PM
01/07/09 12:18 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Comp's Pro Magnum rockers are available only in 1.5s.
The Cranes will work OK in the 1.6, but you'll need to check closely for enough pushrod-to-cylinder head clearance through the full range of lift.
Also, if you're still using unmodified OEM heads, make sure you have enough clearance between the top of the guide / valve seal and the bottom of the retainer at max lift w/ the higher ratio. IIRC, .500"-ish is about the point where OEM guides that haven't been cut down can be an issue.
Re: Comp Rockers or Crane Rockers #186470
01/07/09 12:18 PM
01/07/09 12:18 PM
North Branch, MI, USA
notchbackcuda Offline
poppaj
OK, I'm curious why the Crane's are limited to .620 lift?
Re: Comp Rockers or Crane Rockers [Re: MoparforLife] #186471
01/07/09 12:25 PM
01/07/09 12:25 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i got the comp pro magnums and i'm real happy with them. they don't come in a 1.6 ratio though but the cup style adjuster is nice, it enabled me to keep my pushrods. then i was able to step up to a solid cam later. don't know how much harlands are but i thought the $500ish i spent on the comps was a big chunk of change.
Re: Comp Rockers or Crane Rockers [Re: notchbackcuda] #186472
01/07/09 01:07 PM
01/07/09 01:07 PM
poppaj
because as the lift increases, so does the need for a heavier spring. the cranes will only handle just so much pressure.
Re: Comp Rockers or Crane Rockers [Re: Mopar_Mike] #186473
01/07/09 01:10 PM
01/07/09 01:10 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'm happy with the Comp steel rockers but they're 1.5 only, and the shafts are on intergalactic backorder so if you decide to get them, it's probably going to be awhile.
For a .480 lift cam I'd probably just dig up an old set of Isky iron rockers, cut them all to the same width (because out of the box the width dimensions are all over the place), and would just run them instead. That way you get the advantages of adjustability for a couple hundred bucks, instead of 5 hundred.
Rich H.
Esse Quam Videri
Re: Comp Rockers or Crane Rockers [Re: ZIPPY] #186474
01/07/09 01:17 PM
01/07/09 01:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are there any ductile rockers in the 1.6 ratio(I
didnt think there was but I dont know BB stuff).
Because he wanted 1.6 ratio
Re: Comp Rockers or Crane Rockers [Re: MR_P_BODY] #186475
01/07/09 01:36 PM
01/07/09 01:36 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes there are Mike, Crane 64771-16. They would probably work perfect but I have never used them...just the old Isky stuff they no longer make.
Re: Comp Rockers or Crane Rockers [Re: ZIPPY] #186476
01/07/09 04:14 PM
01/07/09 04:14 PM
Danville, NH
Danville, NH
I have seen the Crane, and in fact have some 1.5 Golds, but not on the engine. I thought my .480 lift cam would benefit with a 1.6 giving a .512 lift. I also saw some Comp rockers (similar to the Crane, not the iron ductile style) on ebay that are 1.6 and about $100 cheaper than a new set of 1.6 Crane, but was worried about durability. I have edelbrock RPM 84cc heads and valves etc. but already know the 1.6 will work with my geometry.
RS23L7 4-Speed
Re: Comp Rockers or Crane Rockers [Re: Mopar_Mike] #186477
01/07/09 04:44 PM
01/07/09 04:44 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Comp 928 dual springs, 540 lift, 6000 hard miles and no problems
Re: Comp Rockers or Crane Rockers [Re: ccdave] #186478
01/07/09 05:33 PM
01/07/09 05:33 PM
The Cranes will only handle so much spring pressure and lift. They are clearanced fit to shaft..No needle bearings at shaft..Aluminium fatigue easy when riding bare against steel shafts with high spring pressure...Where Harland Sharps have needle bearings to ride on at the shaft..Also the crane units will have a clearance problem on larger diameter springs, they will hit the outside edge of the retainer on the bottom side...
poppaj
Re: Comp Rockers or Crane Rockers #186479
01/07/09 07:36 PM
01/07/09 07:36 PM
Airville Pa.
boomer Offline
boomer  Offline
Airville Pa.
poppaj
I am pretty sure the crane roller rockers are bushed........
Re: Comp Rockers or Crane Rockers [Re: ZIPPY] #186480
01/07/09 08:03 PM
01/07/09 08:03 PM
BradH Offline
BradH  Offline
I have, and in a similar application (a small hydraulic street cam). They worked fine.
Re: Comp Rockers or Crane Rockers [Re: Mopar_Mike] #186481
01/07/09 08:04 PM
01/07/09 08:04 PM
BradH Offline
BradH  Offline
... I also saw some Comp rockers (similar to the Crane, not the iron ductile style) on ebay that are 1.6 and about $100 cheaper than a new set of 1.6 Crane, but was worried about durability.
If they're what I think you're talking about... !
Re: Comp Rockers or Crane Rockers [Re: boomer] #186482
01/07/09 08:11 PM
01/07/09 08:11 PM
BradH Offline
BradH  Offline
No needle bearings at shaft...
I don't see any bushings...
Re: Comp Rockers or Crane Rockers [Re: BradH] #186483
01/07/09 08:19 PM
01/07/09 08:19 PM
organ
maximum entropy Offline
organ
the cranes are definitely not bushed. mine have been very reliable.
Re: Comp Rockers or Crane Rockers [Re: maximum entropy] #186484
01/07/09 08:36 PM
01/07/09 08:36 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Same here,I've had no problems at all with my Crane gold rockers.
Nautilus Racing-
