GTX starting problem - bad chrome box? #1864371
07/05/15 04:43 PM
07/05/15 04:43 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
After not starting my '71 GTX for a couple of weeks I started it, it ran for couple of minutes then died. Unable to restart it I thought maybe I'd flooded it so I left it a few hours and was still unable to fire it.
Today I threw a shot of gas down the carb and nothing. Usually it would fire for at least a second.
Is it time to replace the chrome box and ballast?
Thank you.
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: GTX starting problem - bad chrome box? [Re: NOrrTH] #1864391
07/05/15 05:13 PM
07/05/15 05:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
do you have spark at the coil?
Re: GTX starting problem - bad chrome box? [Re: mikemee1331] #1864393
07/05/15 05:17 PM
07/05/15 05:17 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I would start with the ballast resistor. It may have got hot and broke internally. Next would be the coil.
68 Charger R/T 440 auto
Re: GTX starting problem - bad chrome box? [Re: NOrrTH] #1864440
07/05/15 06:34 PM
07/05/15 06:34 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Disconnect the connector at the distributor, turn on the ignition switch and touch the male prong on the engine harness to ground. Each time the prong is grounded and pulled away you should get a spark from the coil. If it sparks, the distributor pickup is the problem, if not it's the ECU, coil, ballast, etc.
Re: GTX starting problem - bad chrome box? [Re: NOrrTH] #1864499
07/05/15 07:59 PM
07/05/15 07:59 PM
AndyF Offline
AndyF  Offline
I've never used that trick. I just stick a paper clip in one of the plug wire boots and see if I get a spark when cranking. Your system is better at debugging the problem than mine!
Re: GTX starting problem - bad chrome box? [Re: NOrrTH] #1864595
07/05/15 09:41 PM
07/05/15 09:41 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
There is a spark, so...what now?
Re: GTX starting problem - bad chrome box? [Re: NOrrTH] #1864633
07/05/15 10:35 PM
07/05/15 10:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
well alrighty then!
where did you test for said spark? coil or plug?
Re: GTX starting problem - bad chrome box? [Re: mikemee1331] #1864642
07/05/15 10:43 PM
07/05/15 10:43 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
well alrighty then!
From the coil
Re: GTX starting problem - bad chrome box? [Re: NOrrTH] #1864804
07/06/15 12:41 AM
07/06/15 12:41 AM
pull the plugs (at least several of em) & see if gas or extremely carbon fouled
Re: GTX starting problem - bad chrome box? [Re: RapidRobert] #1864916
07/06/15 08:52 AM
07/06/15 08:52 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and as you are doing that, make sure the spark is making it to the plug.
