Killerbee, So just a little less backspace and rubbing wouldn't have been a problem. How much clearance did you have between the inside of the tire and wheelhouse setting still? Just trying to get an idea how much movement there is in the back when pushing it. Do you think a 4.75 backspace would give me issues on the outside? Thanks
Also, Jon no need for pics, knowing which tire I can pull up the specs.
Anyone running the Coker Pro Trac N50-15 or M/T Sportsman S/R 28x12-15 in a stock bodied Coronet ?
