03 Chrysler 300m starting issues. #1864405
07/05/15 05:39 PM
07/05/15 05:39 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
I have this Chrysler and last yr in may (2014) it started hard. It threw a code of p0340 which is the cam sensor. I replaced that and it was good. About a month ago it was starting hard again. After a few weeks it threw the same code. After research a cause to this code could be a bad battery. Had the battery tested and it tested bad. After we replaced the battery it ran fine for a week or two. No lights. Then this week it threw cam sensor code again. So I exchanged the sensor under warranty. I replaced it yesterday and now is throwing codes P0340 and P0344. I inspected the plugs and the short pig tail and they both seem to be fine. Has anyone experienced this or can point me in the right direction? HELP ME!! Car has 100k miles with the 3.5l. Thanks, Eric
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon
03 chrysler 300m
10 dodge charger
Re: 03 Chrysler 300m starting issues. [Re: Biggie] #1865057
07/06/15 01:41 PM
07/06/15 01:41 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I don`t know if this is your problem or not but are you replacing it with a mopar sensor? I had issues with a aftermarket one before. I replaced it with a mopar sensor and magnet and it was good to go after that. Also sometimes the crank sensor can go bad and throw that code too IIRC.
Re: 03 Chrysler 300m starting issues. [Re: Biggie] #1865144
07/06/15 03:40 PM
07/06/15 03:40 PM
california
sbcjd Offline
sbcjd  Offline
california
I had a hard starting problem with my 2001 300 M some years ago at 70,000 miles. It turned out I had 2 cracked fuel injectors. The dealer had a difficult time in diagnosing the problem. It went on for several months and multiple trips to the dealer. Fortunately I had an extended warranty.
Re: 03 Chrysler 300m starting issues. [Re: Biggie] #1865407
07/06/15 09:19 PM
07/06/15 09:19 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
I had a 99 300m that needed a crank sensor. Ive been wondering if it could be that. Maybe I will give it ago. No, Im not using mopar sensor. Im using the ones from Orielly auto. I know I know, but Ive had pretty good parts from there the last 10yrs or so.
If the fuel injectors are cracked, don't they spray fuel at all?
Thanks,
Eric
03 chrysler 300m
10 dodge charger
Re: 03 Chrysler 300m starting issues. [Re: Biggie] #1868033
07/11/15 12:47 AM
07/11/15 12:47 AM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
Well, I guess Im going to have to pony up the cash and get the car on a real diagnostic machine. I replace the crankshaft sensor and still starts hard. I was going to check my fuel pressure but I need to buy a special adapter to hook up the gauge because mine wont fit in the little hole it needs to.
03 chrysler 300m
10 dodge charger
