GTX starting problem - bad chrome box?
#1864371
07/05/15 04:43 PM
07/05/15 04:43 PM
Posts: 1,185 Nanaimo, BC
NOrrTH
Nanaimo, BC
After not starting my '71 GTX for a couple of weeks I started it, it ran for couple of minutes then died. Unable to restart it I thought maybe I'd flooded it so I left it a few hours and was still unable to fire it.
Today I threw a shot of gas down the carb and nothing. Usually it would fire for at least a second.
Is it time to replace the chrome box and ballast? Thank you.
'71 GTX N96 auto 3:55
'74 Challenger 440+6 4spd 4:10
'71 Duster 340 auto 4:10
Re: GTX starting problem - bad chrome box?
[Re: mikemee1331]
#1864393
07/05/15 05:17 PM
07/05/15 05:17 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
I would start with the ballast resistor. It may have got hot and broke internally. Next would be the coil.
68 Charger R/T 440 auto
[Re: NOrrTH]
#1864440
07/05/15 06:34 PM
07/05/15 06:34 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Disconnect the connector at the distributor, turn on the ignition switch and touch the male prong on the engine harness to ground. Each time the prong is grounded and pulled away you should get a spark from the coil. If it sparks, the distributor pickup is the problem, if not it's the ECU, coil, ballast, etc.
[Re: NOrrTH]
#1864595
07/05/15 09:41 PM
07/05/15 09:41 PM
NOrrTH
Nanaimo, BC
There is a spark, so...what now?
[Re: NOrrTH]
#1864633
07/05/15 10:35 PM
07/05/15 10:35 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
There is a spark, so...what now? well alrighty then! where did you test for said spark? coil or plug?
[Re: mikemee1331]
#1864642
07/05/15 10:43 PM
07/05/15 10:43 PM
NOrrTH
Nanaimo, BC
There is a spark, so...what now? well alrighty then! where did you test for said spark? coil or plug? From the coil
[Re: NOrrTH]
#1864804
07/06/15 12:41 AM
07/06/15 12:41 AM
RapidRobert
pull the plugs (at least several of em) & see if gas or extremely carbon fouled
[Re: RapidRobert]
#1864916
07/06/15 08:52 AM
07/06/15 08:52 AM
mikemee1331
bethlehem pa
pull the plugs (at least several of em) & see if gas or extremely carbon fouled and as you are doing that, make sure the spark is making it to the plug.
