O/2 sensors on a street/strip car?? #1864263
07/05/15 01:40 PM
07/05/15 01:40 PM
Great Neck,LI,new york
hemi-itis Offline OP
When using o/2's,on the street would I leave them on or remove when not logging. I have heard differing opinions as to the life of the sensor using all the time or when burning leaded or unleaded fuel.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864323
07/05/15 03:09 PM
07/05/15 03:09 PM
AndyF Offline
AndyF  Offline
They don't last very long with leaded fuel but they should last forever with unleaded fuel. I don't think I've ever had to replace an O2 sensor on my daily drivers and I've driven several of them well past 200,000 miles.
On the dyno we replace the O2 sensors on a regular basis when running race gas. It gets super expensive. I'm thinking about switching to a high octane unleaded just to save money on the O2 sensors.
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864339
07/05/15 03:41 PM
07/05/15 03:41 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
As long as the heater is powered up and you are running unleaded gas, the O2 should be okay. Like Andy said, they go for many, many miles in grocery getters. But running them cold, with leaded fuels, or in overly rich conditions certainly shortens their life expectancy.
Master, again and still
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864345
07/05/15 04:01 PM
07/05/15 04:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Also on daily drivers the 02's run at as best a mixture as the controller can adjust to all the time. I mean when its to rich or lean the controller is adjusting all the time to try and run a perfect air/fuel mixture. But on most street cars with carbs until we tune for what ever mixture we are after it wont change and the 02 will see a rich or lean mixture all the time until we adjust the carb so I would think that will be much harder on the 02 sensors also. On our hotrods with carbs we have to make the change so the 02 may run in a not so good mixture for its life alot where on normal drivers they are running in about the best fuel mixture at all times since they are always adjusting mixture from the 02 readings so that may be harder on the 02's life. Even if the 02's have a heater I would think it will be harder on it when used in a non closed loop system. Ron
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864379
07/05/15 04:49 PM
07/05/15 04:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running the same one for several years and two+ of those was w/leaded gas and it`s still goin strong.......
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864388
07/05/15 05:09 PM
07/05/15 05:09 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
So does this all suggest that I should remove them(I have Dual 'Fast' system,,,likely would not buy today as probably better/cheaper units available now) after each use and insert plugs in bung holes. Access to remove is a real pita.
As a second option, just leave display connected to continuously provide power and thereby extend life of sensors.
Car burns unleaded fuel only. 440 Six Pack, therefore carburetors.
Have not yet welded in bungs as am uncertain of answers to these issues and how to best with them. Currently shove up tailpipes using a 'special' mounting mechanism knowing that accuracy likely compromised.
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864395
07/05/15 05:17 PM
07/05/15 05:17 PM
AndyF Offline
AndyF  Offline
For a street car that is going to use unleaded gas I'd go ahead and install at least one O2 sensor and wire it up so that it turns on and off with the ignition. It is just a good idea on a "hot rod" to keep an eye on the AF mixture. For most street engines you don't really need two O2 sensors. Just running one side saves you some money and some wiring.
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864400
07/05/15 05:30 PM
07/05/15 05:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The only time I have mine in is when I'm working on the carb. Once it's tuned I see no need for it being in.
Re: O/2 sensors on a street/strip car?? [Re: justinp61] #1864447
07/05/15 06:43 PM
07/05/15 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On a carb.. take them out after your done playing... why
waste them since in reality your not using them... if your
playing injection...leave them in
wave
Re: O/2 sensors on a street/strip car?? [Re: MR_P_BODY] #1864451
07/05/15 06:50 PM
07/05/15 06:50 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
wave
I agree, my innovate just uses a 18mm, oil pan drain plug from napa for $3
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864475
07/05/15 07:22 PM
07/05/15 07:22 PM
AndyF Offline
AndyF  Offline
I can see that providing the car sees limited street driving. But if you drive the car in different weather conditions or significant elevation changes then having the O2 on board can be helpful. But yeah, if you just drive it around town and head to the track once in awhile then no reason to keep the O2 on all the time.
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864509
07/05/15 08:08 PM
07/05/15 08:08 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Any ideas of what one may experience in decreased life expectancy by leaving them in? 100's of miles, 1000's or 10's of thousands? No race fuel usage.
Given the limit usage some of us give our cars, removing when not used may not be worth the hassle and retaining ongoing ability to monitor could provide some heads up value.
For me if leaving them in caused them to self destruct in less than 5k miles, probably worth removing when not needed.
Re: O/2 sensors on a street/strip car?? [Re: Sxrxrnr] #1864866
07/06/15 02:11 AM
07/06/15 02:11 AM
Just finishing Racepak install. The o/2's also have separate wires for the heater.I'm thinkin to put them on a toggle switch,,,,,on & off. 95% of my driving is on the street so that doesn't seem to shorten sensor life.If Ican make track 4 or 5 times a year I'm thrilled. But life & work get in the way.
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864884
07/06/15 02:50 AM
07/06/15 02:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
With all of the money we spend on our cars, what`s the big deal about buying a $40.00 sensor every so many years. As I stated earlier mine`s fine after at least 6 years street/strip WITH leaded for the first few years and I too leave it in all of the time because carbs aren`t a "set em and forget em" deal. And as far as a toggle switch for the heater that`s crazy.............turn on the power to it, wait for the gauge to count down(if that`s how yours works)and enjoy some DIRECTION in your tuning cos that`s what it is, not the end all. twocents
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1864926
07/06/15 09:46 AM
07/06/15 09:46 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Innovate's LM-1 Manual specifically states
WHEN INSTALLED IN THE EXHAUST, THE OXYGEN SENSOR
MUST BE CONNECTED AND OPERATING WITH THE LM-1
WHENEVER THE CAR IS RUNNING. AN UN-POWERED OXYGEN
SENSOR WILL BE DAMAGED WHEN EXPOSED TO EXHAUST GAS.
p.6
If your datalogger is setup permanently, then leave the WBO2 in unless running leaded fuels. If, like me, the logger is portable, then when not using it, just remove the WBO2 and install the plug. It takes more time for me to remove the wires and T into the vac line than it does to remove the sensor itself.
Re: O/2 sensors on a street/strip car?? [Re: Mattax] #1865061
07/06/15 01:50 PM
07/06/15 01:50 PM
Thanks Matt!
Dom,if the Racepak sensor was $40,,,,,I wouldn't worry about it eek
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1865127
07/06/15 03:08 PM
07/06/15 03:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Gotcha.............not familiar w/all that high-tech stuff................ laugh2
Re: O/2 sensors on a street/strip car?? [Re: hemi-itis] #1865143
07/06/15 03:38 PM
07/06/15 03:38 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I would leave it in as a permanent installation. If the key is on, it's on.
Just driving around and watching what your AFR does will be a learning experience.
Kevin
Re: O/2 sensors on a street/strip car?? [Re: Twostick] #1865388
07/06/15 08:46 PM
07/06/15 08:46 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
That's the way its done on all modern cars built the last 30 or 40 years. When's the last time you replaced one?
