Ac compressor won't cycle off #1863958
07/04/15 10:33 PM
07/04/15 10:33 PM
S.florida
Jupiter331 Offline OP
S.florida
70 440 ac clutch does not disengage. Even if I unplug it. Works fine, blows cold just won't disengage
Re: Ac compressor won't cycle off [Re: Jupiter331] #1863960
07/04/15 10:36 PM
07/04/15 10:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bad clutch.
Re: Ac compressor won't cycle off [Re: Jupiter331] #1864046
07/05/15 12:15 AM
07/05/15 12:15 AM
Maryland
gofastboater Offline
Maryland
Clutch is locked up. When you pull it off, check to see if the bearing isn't locked up. They are replaceable, cheaper than the whole clutch assy.
