Re: voltage regulator
[Re: stateroadhog]
#1862878
07/03/15 03:40 PM
07/03/15 03:40 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Sounds like a bad regulator ground based on the higher than desired voltage and the erratic behavior.
[Re: carhunter]
#1862988
07/03/15 06:54 PM
07/03/15 06:54 PM
RapidRobert
The 731 is as you noted the race reg. get a regular parts house electronic reg & see if your voltage comes back down to an acceptable level. I would not run it until you do
[Re: stateroadhog]
#1863007
07/03/15 07:18 PM
07/03/15 07:18 PM
RapidRobert
Yes definitely something else going on. possibilities are that the green wire from alt to reg is intermittently touching metal/grounding out & making it full field for a split second and related thing with the alt brushes/field circuit (them grounding out & full fielding it. got another alt you could toss in for a quick test? for the "green wire" possibility, a good visual along its length or pull the triangle connector from the flat reg & pull the green wire off of the alt & with a jumper connect alt to reg (side terminal) and jump 12V (blue ign1 circuit) to the reg top terminal. the recessed reg nubs are a slight pain to jump. EDIT I'm wondering if it might be the digital meter? if you have a 12V bulb such as a 1157 lit up nearby does it change brightness when the meter changes reading?
[Re: TJP]
#1863093
07/03/15 09:55 PM
07/03/15 09:55 PM
Posts: 217 Owosso, Michigan
stateroadhog
Owosso, Michigan
Robert hope your still out there. Couldn't leave it alone. Did the green wire bypass 14.2 volts. KOOl so hook everthing back up normal its all working 14.2 volts now I'm really confused. I then relize to easy checking stuff I jump ground DVM to the body. If I ground meter to engine I get 20 volts if I ground it to the body I get 14.2???? I have ground strap from motor to frame. Battery is in trunk grounded to frame. Any thoughts from anybody?
[Re: stateroadhog]
#1863169
07/03/15 11:53 PM
07/03/15 11:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Voltage regulator is grounded to the body, alternator is grounded tot he engine. The problem you are seeing is the ground between the body and the engine is bad.
Run a quicky jumper from the alternator case and voltage regulator and see if everything is as it should be.
[Re: stateroadhog]
#1863353
07/04/15 10:26 AM
07/04/15 10:26 AM
6PakBee
North Dakota
As I suspected, with the two voltage readings, a poor regulator ground. Just not at the firewall. I agree with Supercuda, run a temporary ground between the body and engine and see what you get. One lead of a pair of jumper cables works great for this.
[Re: stateroadhog]
#1863378
07/04/15 10:52 AM
07/04/15 10:52 AM
Supercuda
About to go away
About to go away
up yours
Why are you reinventing the wheel.
Your ground choices are not good ones.
Run the jumper from the ALTERNATOR to the REGULATOR directly.
Anything else is just wasting time.
[Re: stateroadhog]
#1863410
07/04/15 11:37 AM
07/04/15 11:37 AM
6PakBee
North Dakota
After your last post I am not so sure I'm right. Try two things. First with the engine running take a voltage reading between the alternator case and the body. This will check how good the ground is. Second with the engine running take a voltage reading between the output stud of the alternator and the battery post on the starter relay (I'm assuming that's where you terminated your remote battery lead). This will check for voltage drop on the positive side. Problem may be on the positive side and not the negative (ground) side.
[Re: stateroadhog]
#1863450
07/04/15 12:19 PM
07/04/15 12:19 PM
6PakBee
North Dakota
Both cases are similar. If you have a good ground between the case and body you should read close to 0 volts. If you have anything else, what you are measuring is the voltage drop through a poor ground connection(s). If you have a good connection between the alternator output stud and the starter relay stud, you should again read close to 0 volts. If you have anything else, what you are measuring is the voltage drop through a poor connection(s) on the positive side. You have to keep in mind that the system voltage the regulator is using for a 'sense' voltage is coming from the stud on the starter relay through the ignition switch.
