Re: b-body k member question ??
[Re: D_C]
#1862265
07/02/15 06:29 PM
07/02/15 06:29 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Physically they will fit, but they have different types of sway bar mounting. No sway bar? No big deal.
[Re: 2abodymcodes]
#1862669
07/03/15 08:19 AM
07/03/15 08:19 AM
Posts: 11,840 Florida
mopar346
Let me tell ya about fat chicks!
Something about the E-body box using shims in some cases, maybe later years?
Careful, your character's showing!
[Re: thehemikid]
#1862702
07/03/15 09:46 AM
07/03/15 09:46 AM
Posts: 5,186 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
There was a discussion about this not long ago here on Moparts and seems like the E body steering box bracket mounts the box at a slightly different angle, but my memory on that has faded. I remember something about that too...
...FAFO...
[Re: 2abodymcodes]
#1863202
07/03/15 11:37 PM
07/03/15 11:37 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Word I got was when Borgeson mocked up their steering box, they used a 'B' body K member. This was given as the excuse why some with E Bodies(I was one) had severe alignment issues when installing this box. I got this from a reliable source. Corrective shimming of steering box finally removed my alignment issues. This is not proof positive that there may be a difference, but should cause one to do what you are doing,,,asking the question.
Yes I am aware of incorrect steering box bolts. My originals were buggered, so to get car together in a timely manner I picked these grade 8's at the local hardware store. Now have a set of correct bolts, just need to put them in,,,,kind of a pita so been putting it off. Expensive little buggers too
[Re: 2abodymcodes]
#1863218
07/03/15 11:53 PM
07/03/15 11:53 PM
Posts: 12,528 Western Colorado High Desert
moparmarks
66-69B uses a different sway bar setup than 70-72B 62-70B has a different steering box angle than 71-2B, about 2-4* 70B is a one year one K-frame that has the 62-70 angle but the 70-72 sway bar setup. 71-2B is the same as 70-4E 69 K will fit in your 71 but would need the 66-69B lower control arms and sway bar if wanted. Also might have to shim the box a bit.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1863502
07/04/15 12:28 PM
07/04/15 12:28 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
66-69B uses a different sway bar setup than 70-72B 62-70B has a different steering box angle than 71-2B, about 2-4* 70B is a one year one K-frame that has the 62-70 angle but the 70-72 sway bar setup. 71-2B is the same as 70-4E 69 K will fit in your 71 but would need the 66-69B lower control arms and sway bar if wanted. Also might have to shim the box a bit. There is also a later 69 k-frame like the 70 style just not drilled for the newer sway bar setup.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Kern Dog]
#1864789
07/05/15 11:19 PM
07/05/15 11:19 PM
Posts: 75,391 A gulag near you.
JohnRR
A gulag near you.
Physically they will fit, but they have different types of sway bar mounting. No sway bar? No big deal. There is more to it than just that
Mainstream Media is the new Pravda
[Re: Sxrxrnr]
#1864794
07/05/15 11:27 PM
07/05/15 11:27 PM
JohnRR
A gulag near you.
Was this RELIABLE source the same rocket scientist that told you that there are different size oil pan bolts ? That is some bogus info, steering boxes interchange between the different body platforms ( except for certian C barges) so it wouldn't matter if Borgensen used a b body or E body Kframe, the misalignmnet between an E body and 70 down B body would be with the steering column and not any of the steering linkage ... and if it were a 71-72 B k frame that is the same as E body.
[Re: JohnRR]
#1864902
07/06/15 04:55 AM
07/06/15 04:55 AM
Sxrxrnr
Northern Calyfornua
Was this RELIABLE source the same rocket scientist that told you that there are different size oil pan bolts ? That is some bogus info, steering boxes interchange between the different body platforms ( except for certian C barges) so it wouldn't matter if Borgensen used a b body or E body Kframe, the misalignmnet between an E body and 70 down B body would be with the steering column and not any of the steering linkage ... and if it were a 71-72 B k frame that is the same as E body. Ready! Fire! Aim! Father, forgive them; for they know not what they do.
[Re: JohnRR]
#1864906
07/06/15 06:13 AM
07/06/15 06:13 AM
Sxrxrnr
Northern Calyfornua
Was this RELIABLE source the same rocket scientist that told you that there are different size oil pan bolts ? That is some bogus info, steering boxes interchange between the different body platforms ( except for certian C barges) so it wouldn't matter if Borgensen used a b body or E body Kframe, the misalignmnet between an E body and 70 down B body would be with the steering column and not any of the steering linkage ... and if it were a 71-72 B k frame that is the same as E body. This certainly cannot be the same self appointed Mopar expert who once so stridently claimed that big block oil pans were factory bolted on with all 20 bolts of the same length. As it turns out, the bolts that affix the pan to the block as documented by both Motor's and by the Chrysler Parts Catalog were exactly 1/4th longer than those that affix the pan to the rear retainer. One would have thought a normal person after having his head so throughly handed to him on this topic, cease stirring the pot with his continuous sniping and personal attacks which to date I have ignored. See my comment in the posting directly above this one. Incidentally the reliable source rocket scientist who shared this information that a 'B' body was used to mock up the steering box for Mopar's was an employee of Borgeson. I made no assertion that this was the direct cause of the shimming requirement for this box when used on an E Body. The party at borgeson had suggested this could be the cause of the issues I experienced and as it turns out, others. There are multiple threads discussing this on the forum. That was until it was shown in thread postings discussing this, that it came out that old Motor's Repair Manuals specifically warned that of the 20 attachment bolts that the 2 for the rear main retainer were shorter by 1/4 inch than the 18 for the block. This then suggested that if the longer bolts were utilized in the rear main retainer that a massive oil leak would occur because they would bottom out or worse yet crack the retainer before the oil pan was cinched tightly. If one were to purchase a Mr. Gasket oil pan bolt set, all 20 are the identical longer length. Then this same expert attempted to divert his demonstrated ignorance of the topic by suggesting that anyone who trusted a rag such as he implied Motor's to be, was a fool. But much to this man's chagrin and sorrow a posting by John Kunkel in this thread at entry number 1659842 dated 8-19-2014 gave this identical information by a reference copied verbatim from a Chrysler Corporation parts catalog, putting to bed his fiction to coverup his original incorrect assertions. Below is the thread to this URL. I recommend reading the entire thread, but if not just skip down to Kunkel's posting at 1659841 and commence reading from there on. https://board.moparts.org/ubbthreads/ubbt...tml#Post1659850Below is the URL on another thread started by me on this issue of leaking rear main seals and leaking pan gaskets on Mopars. Again this same expert in his misguided attempts to appear relevant(I've noted this phenomenon often by this expert since joining this forum) to many topics where his expertise has been a bit underwhelming. https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/8088189/site_id/1#importSome may question why I bring this forth now. Frankly I've tired of the bitter cheap shots taken by this gentlemen, not only at me but others who have been the target of his apparent unhappiness with his likely empty life and finds a perverse pleasure at belittling those who may have come to this forum, perhaps having limited experience with Mopar idiosyncrasies(but often a great deal with other marquees)and are hoping that the help they seek in resolving will the be willingly shared by those in the know,I can only assume that I became a target of his wrath because he was proven incorrect in this case. Ironically, it was not I, but other forum members who put forth evidence demonstrating this, both from Motor's and Chrysler.
[Re: JohnRR]
#1866075
07/07/15 07:51 PM
07/07/15 07:51 PM
Posts: 18,436 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
