1964 polara 505 max wedge #1862605
07/03/15 03:09 AM
07/03/15 03:09 AM
wisconsin united states
K
keith airgrabber Offline OP
Right in the Nutz!!!
K
was a 383 auto. Now a 4-speed. Drove it for first time. What a nice ride.My Dad and I did a
ll the work. Minus machining/balancing on engine
Re: 1964 polara 505 max wedge [Re: keith airgrabber] #1862612
07/03/15 03:23 AM
07/03/15 03:23 AM
K
K
more pics
Re: 1964 polara 505 max wedge [Re: keith airgrabber] #1862719
07/03/15 11:15 AM
07/03/15 11:15 AM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
nice work! it's a great sleeper.
HEMI,S ARE FOREVER!!!
Re: 1964 polara 505 max wedge [Re: keith airgrabber] #1862734
07/03/15 11:36 AM
07/03/15 11:36 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
beautiful!
1981 Dodge D150 360 auto
Re: 1964 polara 505 max wedge [Re: basketcase] #1866858
07/08/15 08:43 PM
07/08/15 08:43 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Very nice!
Can you give some details on the components you used for the build?
'63 Dodge 330
11.19 @ 121 mph
Re: 1964 polara 505 max wedge [Re: GY3] #1888588
08/10/15 03:53 AM
08/10/15 03:53 AM
K
K
It has TTI max wedge exhaust with cutouts. I have not ran it with caps open yet. Exhaust manifolds,intake is original 63. Heads max wedge. And are 286 castings original from a 63 dodge. Took me 8 years to save cash and round everything up. Even the shifter is a 64-65 piece. (squared off top on shifter. remakes are not like it). floor hump was from brewers performance. Have a RAM HD clutch bore and beck style. I like Garbage truck pedal. It suits me fine. Bought a radio delete plate on ebay for 15 bucks. And scored carpet for 40 bucks on craigslist. Put spme belts in the back seat from a 66 charger. They are black with a silver buckle. To match front belts. Was an air conditioning car. My dad found a dash from a 64 plymouthat a junkyard. I painted it up and we also got a non air heater box from the same car. It has been a fun project. It has been a dream of mine to build a max wedge car since the first time I read an article about a 62 in Mopar Muscle. 1991. I was 14 years old.Man time sure flys.I cranked torsion bars down a bit to give it a nascar kind of look.It has 3:23 sure-grip and 23 spline 4-speed.
Re: 1964 polara 505 max wedge [Re: keith airgrabber] #1888591
08/10/15 04:02 AM
08/10/15 04:02 AM
K
K
air cleaners are steel remakes. Carbs are original 3447 carter. No chokes. Just turn on electric fuel pump. Steering column was swapped out and steering gear to manual steering. Hood bracing was not cut out. Stock hood clears air cleaner just fine. Original max wedge had the inner hood bracing cut out.
Re: 1964 polara 505 max wedge [Re: keith airgrabber] #1888617
08/10/15 09:24 AM
08/10/15 09:24 AM
6T4 Polara Offline
6T4 Polara  Offline
Great build and thank you for sharing.
