Re: msd 8636 crank trigger
[Re: dodgeram1998]
#1862071
07/02/15 03:12 PM
07/02/15 03:12 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
The addition of the crank trigger wheel will push your crank pulley/drive mandrel out the thickness of the wheel. If you have an electric water pump and are just running an alternator and/or vacuum pump, it shouldn't be a big deal to change the spacing. Unless you're running a factory alternator and bracket...that could be a pain.
[Re: dodgeram1998]
#1862102
07/02/15 03:55 PM
07/02/15 03:55 PM
an8sec70cuda
The pickup will have to be mounted on the driver's side in that case. There's a member here who sent me a pic of his done that way a while back...can't remember his screen name right now.
[Re: dodgeram1998]
#1862117
07/02/15 04:24 PM
07/02/15 04:24 PM
an8sec70cuda
The member is '72CudaRacer. I just did a quick search and found this pic he had posted a while back...
