Pulley alignment issue #1861923
07/02/15 12:17 PM
07/02/15 12:17 PM
Va Usa
beecrazy Offline OP
beecrazy  Offline OP
Va Usa
Guys
I'm having a problem with my crank and water pump pulleys not being aligned. I think that my harmonic balancer is not installed all the way.
Should the end of the crank be flush with the hub of the balancer ?
I think this is the balancer I have.
http://www.summitracing.com/parts/sum-b64279/overview/make/dodge
Kevin
Re: Pulley alignment issue [Re: beecrazy] #1861936
07/02/15 12:37 PM
07/02/15 12:37 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you put the final torque on the balancer bolt, it should have seated completely as that is a bit of foot pounds. 140 foot or so IIRC. Stock balancers usually stick out 1/8 inch or less from end of crank snout. Not sure about your summitt unit.
Re: Pulley alignment issue [Re: beecrazy] #1861943
07/02/15 12:44 PM
07/02/15 12:44 PM
USA
Hooligan Offline
Hooligan  Offline
USA
There should be some space between the end of the crank and the balancer. I don't know how much at this time, but from memory I would say about a 1/4''. In fact, I have pulled apart several Mopar engines where the balancer washer was crushed inward from over tightening.
Re: Pulley alignment issue [Re: beecrazy] #1861944
07/02/15 12:45 PM
07/02/15 12:45 PM
USA
Hooligan Offline
Hooligan  Offline
USA
BTW... Beecrazy in an excellent nickname!
Re: Pulley alignment issue [Re: beecrazy] #1862013
07/02/15 02:12 PM
07/02/15 02:12 PM
are your pump/alt pulleys aligned and just the crank pulley itself is too far forward? IF the dampener ain't seated then correct that & go from there. if it IS seated then you can move the alt forward & space the pump pulley forward (you can only gain so much tho on the pump as there is only so much nub forward from the "cross" to work with) or you can source a shallower pump pulley (I have some). Speedway mtrs and others has spacers for the pump pulley
Re: Pulley alignment issue [Re: beecrazy] #1862066
07/02/15 03:05 PM
07/02/15 03:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Was the combination of pulleys you have ever used successfully before? If the pulley combo is new, I'd suspect a simple mismatch.
Re: Pulley alignment issue [Re: John_Kunkel] #1862098
07/02/15 03:49 PM
07/02/15 03:49 PM
Va Usa
beecrazy Offline OP
beecrazy  Offline OP
Va Usa
Guys
Thanks for the input. I had to take off balancer last year to replace seal, but I did not take a good look at alignment before I removed it frown.
The water pump pulley is the one that does not look like its aligned. The power steering and the alternator look ok.
I will check the balancer and crank tonight. I did torque it to 135 lbs.
Kevin
Re: Pulley alignment issue [Re: beecrazy] #1862461
07/02/15 11:36 PM
07/02/15 11:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Well, the way I see it is that if the balancer wasn`t on all the way on then all the pulleys should not line up. If one lines up and not the other then it must be a mismatch in pulleys or possibly brackets. But since you said the water pump one doesn`t line up then I say the pulley.
