Re: backfiring through carb [Re: Bdrainy] #186102
01/15/09 10:22 PM
01/15/09 10:22 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
What are the specs on the cam? If it's not bumpy 15in of vacuum is late ign. timing and it would do what you say it's doing. Whats you total timing at?
Re: backfiring through carb [Re: rrunner] #186103
01/15/09 11:04 PM
01/15/09 11:04 PM
A slight vac leak will still let it stay steady(usually just a bit lower of a reading) as there's no intermittent interruption in the intake tract(which would make the vac gauge jump around) only that the mixture air/fuel ratio in the intake tract is now off enough to cause driveability issues. but if it got lean enough to cause a lean misfire then that would cause the gauge to dive for a split second as that cyl didn't do it's job.
Re: backfiring through carb [Re: rrunner] #186104
01/16/09 01:05 AM
01/16/09 01:05 AM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
It is the comp cams XE275HL. here are the specs:
Intake Duration at 050 inch Lift: 231
Exhaust Duration at 050 inch Lift: 237
Duration at 050 inch Lift: 231 int./237 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 287
Advertised Duration: 275 int./287 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Re: backfiring through carb [Re: Bdrainy] #186105
01/17/09 04:22 PM
01/17/09 04:22 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Are you still using points? sounds like a bad distributor to me. Do you have the vacuum advance hooked up?? It should be on ported vacuum and not manifold. manifold will make it backfire when letting off as it pulls the timing a way up.
Re: backfiring through carb [Re: Dodgem] #186106
01/17/09 06:11 PM
01/17/09 06:11 PM
utah
moparhinck Offline
moparhinck  Offline
utah
if your carb goes lean it will backfire on you, and since it doesn't pop when you ease into it, I would look there
1969 440 4 speed Polara 2dr 1977 Cordoba (daily driver) 1965 dart gt (my first car)
Re: backfiring through carb [Re: BigBird] #186107
01/17/09 06:53 PM
01/17/09 06:53 PM
ky.
K
kenworth_goose Offline
K
ky.
Sounds like the chain is off a tooth or two....
chain off one or two teeth will never make it pop through the carb. I used to run all of my 318's one tooth fast and boy does it make one run good. Check the valve springs. Pull the rockers and see if you can push any of them open with your hand.
Re: backfiring through carb [Re: kenworth_goose] #186108
01/22/09 05:14 PM
01/22/09 05:14 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
Well I seem to have fixed the issue. It ran a lot better after I pulled everything off and reinstalled the timing chain, but was still backfiring under hard acceleration.
I made the mistake of setting the initial timing with the vacuum advance hooked up. I realized this and as soon as I unhooked it, my timing dropped from 15 to 5 initial... I reset the timing to 15 and took it for a ride (with the vacuum advance still unhooked and capped off) and it ran great. I still haven't hooked it back up yet.
Thanks all for the help in what to look for! As always, it is appreciated. - Brian
Re: backfiring through carb [Re: Bdrainy] #186109
01/22/09 05:35 PM
01/22/09 05:35 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Good for you.
I am glad it wasn't something to painful$.
Just goes to show you we all forget things from time to time. Hook that advance back up and go have some fun.
