exhaust manifold hardware #1858243
06/27/15 04:40 PM
06/27/15 04:40 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
What are people doing to their manifold studs and nuts to prevent corrosion?
Im installing manifolds with new hardware and was curious to what you guys do.
Re: exhaust manifold hardware [Re: LimeliteAero] #1858328
06/27/15 07:42 PM
06/27/15 07:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I usually switch the studs/hardware out to Stainless Steel and use Copper Never-Seize (1800 degree rating)on the threads
And I use (long) brass manifold nuts on the pipe to flange nuts
Re: exhaust manifold hardware [Re: DAYCLONA] #1858752
06/28/15 11:12 AM
06/28/15 11:12 AM
SE Pa.
SE Pa.
Thanks Mike, but I was interested in what people are doing to their original hardware IE: RPM or painting
Re: exhaust manifold hardware [Re: LimeliteAero] #1859611
06/29/15 01:33 PM
06/29/15 01:33 PM
None
71rm23 Offline
71rm23  Offline
None
Stage 8 hardware
Re: exhaust manifold hardware [Re: LimeliteAero] #1860395
06/30/15 11:50 AM
06/30/15 11:50 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Put it in a big zip lock baggie and suck all the air out ???
what look are you going for with the manifolds , blasted bare metal , or painted the way it rolled off the assembly line ?
Re: exhaust manifold hardware [Re: JohnRR] #1860471
06/30/15 01:26 PM
06/30/15 01:26 PM
SE Pa.
SE Pa.
Im not doing the factory procedure because its my cruiser convertible but was just trying to keep the nuts and studs from rusting as long as possible.
Since you mentioned it, How come we dont see manifolds with turquiose overspray?
Re: exhaust manifold hardware [Re: LimeliteAero] #1860510
06/30/15 02:11 PM
06/30/15 02:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: exhaust manifold hardware [Re: DAYCLONA] #1860514
06/30/15 02:18 PM
06/30/15 02:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: exhaust manifold hardware [Re: LimeliteAero] #1860556
06/30/15 03:12 PM
06/30/15 03:12 PM
JohnRR Offline
JohnRR  Offline
^^^^^^ haha
Re: exhaust manifold hardware [Re: LimeliteAero] #1860558
06/30/15 03:13 PM
06/30/15 03:13 PM
JohnRR Offline
JohnRR  Offline
Then you need to get stuff that doesn't rust , or paint after every heat cycle ?
Stainless steel nuts and studs ????
Re: exhaust manifold hardware [Re: LimeliteAero] #1860562
06/30/15 03:19 PM
06/30/15 03:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct? Then you better use factory bolts because the head markings will be wrong if you dont. .02
Re: exhaust manifold hardware [Re: LimeliteAero] #1860772
06/30/15 07:58 PM
06/30/15 07:58 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I just paint the edge of the manifold where it butts up to the head ,,covering the hardware in engine color
ps, there are NO head markings of any kind on B/RB exhaust manifold to head hardware .
Re: exhaust manifold hardware [Re: LimeliteAero] #1860809
06/30/15 08:55 PM
06/30/15 08:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Small blocks did Bill up
Re: exhaust manifold hardware [Re: ScottSmith_Harms] #1860845
06/30/15 09:38 PM
06/30/15 09:38 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Scott no one cares about those tiny engines!!!!! Just kidding
Ron
Re: exhaust manifold hardware [Re: LimeliteAero] #1860863
06/30/15 09:55 PM
06/30/15 09:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ron
Yet all the pictures posted above are of /6's or small blocks whistling
laugh2
Re: exhaust manifold hardware [Re: ScottSmith_Harms] #1861017
07/01/15 01:32 AM
07/01/15 01:32 AM
JohnRR Offline
JohnRR  Offline
Ron
laugh2
He said he wanted to see blue engines with manifolds painted ...
You can't see bolt head markings with the hood closed while doing the speed limit either ...
PLUS ... if you actually READ his question you would have seen that your answer has no bearing on the question ...
There is nothing there about BOLT HEADS ...
Re: exhaust manifold hardware [Re: LimeliteAero] #1861026
07/01/15 01:55 AM
07/01/15 01:55 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
John, are there rules in posting a reply? If I've broken any please excuse me.
But just so you can un bunch your undies John (don't want to cause a rash laugh2 ).....
Here's what I do. Nothing, clean them, install them, paint them like factory.
There are no brush on coatings like RPM that I am aware of that will withstand exhaust manifold temps enough to prevent rust on a plain steel part, Maybe Jet Hot or some type of ceramic coating but then what's the point? That said if you only drive the car sparingly in nice weather the cleaned and painted factory stuff will probably stay pretty nice for a long time. If you want better results then you'd likely need to replace them with aftermarket bolts made from a rust resistant metal.
twocents
Re: exhaust manifold hardware [Re: LimeliteAero] #1861823
07/02/15 05:03 AM
07/02/15 05:03 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
FWIW I've had pretty good results by coating the bare steel studs and nuts with phosphoric acid based Rust Cure:
http://www.rust-cure.com/
A coating does no perceptible etching as a dipping in acid would, but the Rust Cure bakes on and stays on for years and hundreds of heat cycles and the metal doesn't rust. And use the anti-seize.
