backfiring through carb #186082
01/06/09 08:21 PM
01/06/09 08:21 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
Hi all,
I just swapped out my cam in my 70 road runner and I am now getting a backfiring through the carb. I know the usual reason are lean, vacuum leak, timing, or valve train issues.
I changed the cam without pulling the engine and when I put the distributor back in and went to fire it up I somehow ended really really advanced. It was kicking back against the starting but it ran just wouldn't idle.
So I retarded the timing and it starts up and runs fine. But if I rev up the engine it backfires through the carb. I can bring the rpms up slowly and it seems fine, but if I stab at the gas it backfires.
I have not had a chance the mess with it too much, but was looking for any tips on what to check for besides what I listed above. I will throw a vacuum gauge on it tonight also, but what should I look for on that and what will it tell me exactly.
Re: backfiring through carb [Re: Bdrainy] #186083
01/06/09 08:38 PM
01/06/09 08:38 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Check, check and double check your firing order and wire location. It is opposite of a small block as far as rotation. After all the years of doing this stuff you tend to get lax. I know because I did just that.
Re: backfiring through carb [Re: Bdrainy] #186084
01/06/09 08:41 PM
01/06/09 08:41 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Firing order first. Then pull the wires one at a time to see if you can tell what cylinder it is.
New or used cam and lifters?
Re: backfiring through carb [Re: NITROUSN] #186085
01/06/09 08:52 PM
01/06/09 08:52 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
It is a used cam, from a previous motor I had. Ran fine when I pulled it. I only ran it about 500 miles or so. New lifters though.
Didn't think of pulling each plug one at a time. I am really hoping that I didn't wipe a cam lobe.
Could it have hurt anything when it was really advanced and kicking back against the starter?
Re: backfiring through carb [Re: Bdrainy] #186086
01/06/09 08:59 PM
01/06/09 08:59 PM
MNobody Offline
MNobody  Offline
If it's got a Holley carb you might have blown a PV if it backfired and doesn't have protection. But i believe you would have a rich condition if it did.
Re: backfiring through carb [Re: MNobody] #186087
01/06/09 09:03 PM
01/06/09 09:03 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
it does have a holley carb, but I thought they had some type of protection in them now that prevents the pv from being blown....?
Re: backfiring through carb [Re: Bdrainy] #186088
01/06/09 10:42 PM
01/06/09 10:42 PM
Buzzardbreath Wyoming
BigBird Offline
BigBird  Offline
Sounds like the chain is off a tooth or two....
Re: backfiring through carb [Re: BigBird] #186089
01/06/09 10:42 PM
01/06/09 10:42 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
MORE
Re: backfiring through carb [Re: 05dakota] #186090
01/06/09 10:49 PM
01/06/09 10:49 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
MORE
More what...? You think the chain might be off more than a tooth or two?
That is a easy enough fix, but I just hate to pull the whole front end off again....
Re: backfiring through carb [Re: Bdrainy] #186091
01/06/09 11:02 PM
01/06/09 11:02 PM
BigBird Offline
BigBird  Offline
MORE
When a chain jumps a tooth you can make it run by changing the timing but it will have no power. It will act like yours sounds. Not saying that you got it off but I would suspect it as you have just had it all apart and changed the cam. I would hate to pull it all apart also but if all else fails that is where I would look.
Re: backfiring through carb [Re: BigBird] #186092
01/06/09 11:20 PM
01/06/09 11:20 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
Thanks for replies. I got some garage time ahead of me.
Re: backfiring through carb [Re: NITROUSN] #186093
01/06/09 11:33 PM
01/06/09 11:33 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
check the firing order. im telling you it GO CHECK IT.
it got me this summer. 5 and 7 were swapped and it backfired like no tomorrow.
Re: backfiring through carb [Re: aarcuda] #186094
01/06/09 11:35 PM
01/06/09 11:35 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
Yeah, I will check everything I possibly can before I pull the front end the motor apart again...
Re: backfiring through carb [Re: Bdrainy] #186095
01/07/09 12:40 PM
01/07/09 12:40 PM
New Brunswick, Canada
CoyoteJack Offline
CoyoteJack  Offline
If you can't find a couple of wires in the wrong spot, then I think BigBird nailed it. I did this once when I was in to much of a hurry and the engine acted exactly like you discribe. Ended up that I had lined up the timing mark on the cam sprocket with one of the dimples on the crank sproket, not the timing mark. I was very lucky not to bend any valves and after I fixed the problem the engine worked perfectly.
Jack
Re: backfiring through carb [Re: CoyoteJack] #186096
01/15/09 06:01 PM
01/15/09 06:01 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
Ok, so I finally got back out the garage checked the firing order and everything was as it should be.
I ended up taking the front end apart and made sure the timing marks were lined, they were. But I pulled the timing chain off and re installed it just to make sure.
I got it all back together and fired it up and it runs a lot better now...but there is still a couple issues.
The first is the timing mark is jumping and it seems rythmic. The timing will be there then every second or two is dissappears and the comes back....
I took it for a spin around the block and if I accelerate normal everything seems fine, but if I put my foot into it backfires.
Is this my timing chain is toast? or a vacuum leak? I did throw my vacuum gauge on it and at idle in gear the vacuum gauge showed 15 and it pretty steady..... I threw in the towel late last night and am going to step away from it for a day or two, but any ideas would be great! thanks - Brian
Re: backfiring through carb [Re: Bdrainy] #186097
01/15/09 07:47 PM
01/15/09 07:47 PM
As you may notice, I am not much on posting, and I have not been here in a while, but I am sure some of the seasoned gear heads can answer the question as to the resutls of a cam without proper valve spring pressure?
Rob (First post!) :-)
Re: backfiring through carb [Re: Bdrainy] #186098
01/15/09 08:28 PM
01/15/09 08:28 PM
The first is the timing mark is jumping and it seems rythmic. The timing will be there then every second or two is dissappears and the comes back.... Brian
When I have experienced that it was from the timing light not clamped on securely. EDIT I keep coming back to secondary ign related or vac leak in that order
Re: backfiring through carb [Re: Bdrainy] #186099
01/15/09 08:39 PM
01/15/09 08:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Where are you setting the base timing at? (degrees)
Re: backfiring through carb [Re: buildanother] #186100
01/15/09 09:31 PM
01/15/09 09:31 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
trying to set it at 15 intitial, but it was hard with it bouncing. It was at the end of a long day, so i just as i started getting frustrated, i decided it was a good time stop for the night.
IF i had a vacuum leak, wouldn't my vacuum gauge been all over the place? it was steady at 15....
Re: backfiring through carb [Re: Bdrainy] #186101
01/15/09 10:17 PM
01/15/09 10:17 PM
chicagoland,usa
chicagoland,usa
Steady 15 sounds good especially if a non stock cam.
