T/A Radio Delete? #1860566
06/30/15 03:25 PM
06/30/15 03:25 PM
Muskegon MI
Jerrari Offline OP
Jerrari  Offline OP
Muskegon MI
Hey Guys. I have searched through the archives and cannot seem to find the answer to my question. I have no radio codes on my build sheet, it is blank. So would that mean radio delete or would that be maybe a default to just an AM? Also, if it is a radio delete, would I have had an antenna from the factory? Thanks is advance! Jerry.
Re: T/A Radio Delete? [Re: Jerrari] #1860569
06/30/15 03:29 PM
06/30/15 03:29 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
I can answer this partially. Not sure on the broadcast sheets however my brother has a radio delete T/A meaning there is not an "R.." code on the fender tag for the radio and his does not and never did have a hole on the quarter for the antenna.
Re: T/A Radio Delete? [Re: Jerrari] #1860637
06/30/15 05:22 PM
06/30/15 05:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No radio - standard.
All radios were options, so it is not a 'delete' since you do not add something & then take it away, it simply had no radio.
With no radio, no antenna or hole.
Re: T/A Radio Delete? [Re: Jerrari] #1860642
06/30/15 05:25 PM
06/30/15 05:25 PM
Muskegon MI
Jerrari Offline OP
Jerrari  Offline OP
Muskegon MI
Thanks!!
Re: T/A Radio Delete? [Re: Alaskan_TA] #1860669
06/30/15 05:42 PM
06/30/15 05:42 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
How common is it Barry as I would think many people ordering these cars would have assumed the car came with some kind of radio and therefore not checked the box for a radio. Do you see many on the registry without radios?
Re: T/A Radio Delete? [Re: Jerrari] #1860720
06/30/15 06:41 PM
06/30/15 06:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Some dealerships ordered T/As, but I have not seen one yet that was actually ordered by someone off the street.
I do not track radio options on these cars, but I have seen several T/As without radios.
Re: T/A Radio Delete? [Re: Alaskan_TA] #1861502
07/01/15 08:47 PM
07/01/15 08:47 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I have an AAR Cuda no radio code on tag I don't have build sheet it never had an antenna but there is a standard am radio in the hole it never had a block off panel. Mine is a crazy option car column shift auto manual steering power brakes no radio. I suppose they thought it would be to hard to steer a manual and tune the radio. Hah Hah.
