Gear Box Worm Shaft Seal #1860607
06/30/15 04:31 PM
06/30/15 04:31 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
Best place to buy a new worm shaft seal for the gear box. 72 Duster with power steering. How hard is it to change on the car with stock manifolds?
Re: Gear Box Worm Shaft Seal [Re: 70dart318] #1860702
06/30/15 06:16 PM
06/30/15 06:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Slant 6?
V8?
Changed the pitman arm shaft seal on a 72 Swinger, that was a PITA but I got the parts from Napa no sweat. That was 20+ years ago though...
Rockauto shows three suppliers, NAPA or someone local should be able to at least cross one of those numbers for you if nothing else.
PS, the FSM is your friend here.
Don't be the exception.
Re: Gear Box Worm Shaft Seal [Re: Supercuda] #1860848
06/30/15 09:41 PM
06/30/15 09:41 PM
Streetsboro,Ohio
Streetsboro,Ohio
318 with iron manifolds
Re: Gear Box Worm Shaft Seal [Re: 70dart318] #1860930
06/30/15 11:04 PM
06/30/15 11:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dunno how hard it'd be, but I imagine the manifold being out of hte way would help.
