Re: exhaust manifold hardware
[Re: LimeliteAero]
#1860395
06/30/15 11:50 AM
06/30/15 11:50 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Thanks Mike, but I was interested in what people are doing to their original hardware IE: RPM or painting Put it in a big zip lock baggie and suck all the air out ??? what look are you going for with the manifolds , blasted bare metal , or painted the way it rolled off the assembly line ?
[Re: LimeliteAero]
#1860510
06/30/15 02:11 PM
06/30/15 02:11 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Since you mentioned it, How come we dont see manifolds with turquiose overspray?
[Re: DAYCLONA]
#1860514
06/30/15 02:18 PM
06/30/15 02:18 PM
Posts: 18,160 Mass
DAYCLONA
Mass
[Re: LimeliteAero]
#1860558
06/30/15 03:13 PM
06/30/15 03:13 PM
JohnRR
Im not doing the factory procedure because its my cruiser convertible but was just trying to keep the nuts and studs from rusting as long as possible.
Since you mentioned it, How come we dont see manifolds with turquiose overspray? Then you need to get stuff that doesn't rust , or paint after every heat cycle ? Stainless steel nuts and studs ????
[Re: ScottSmith_Harms]
#1860845
06/30/15 09:38 PM
06/30/15 09:38 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Small blocks did Bill Scott no one cares about those tiny engines!!!!! Just kidding Ron
#1861017
07/01/15 01:32 AM
07/01/15 01:32 AM
JohnRR
Scott no one cares about those tiny engines!!!!! Just kidding Ron Yet all the pictures posted above are of /6's or small blocks He said he wanted to see blue engines with manifolds painted ... You can't see bolt head markings with the hood closed while doing the speed limit either ... PLUS ... if you actually READ his question you would have seen that your answer has no bearing on the question ... What are people doing to their manifold studs and nuts to prevent corrosion? There is nothing there about BOLT HEADS ...
[Re: LimeliteAero]
#1861026
07/01/15 01:55 AM
07/01/15 01:55 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
John, are there rules in posting a reply? If I've broken any please excuse me. But just so you can un bunch your undies John (don't want to cause a rash )..... Here's what I do. Nothing, clean them, install them, paint them like factory. There are no brush on coatings like RPM that I am aware of that will withstand exhaust manifold temps enough to prevent rust on a plain steel part, Maybe Jet Hot or some type of ceramic coating but then what's the point? That said if you only drive the car sparingly in nice weather the cleaned and painted factory stuff will probably stay pretty nice for a long time. If you want better results then you'd likely need to replace them with aftermarket bolts made from a rust resistant metal.
[Re: LimeliteAero]
#1861823
07/02/15 05:03 AM
07/02/15 05:03 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
FWIW I've had pretty good results by coating the bare steel studs and nuts with phosphoric acid based Rust Cure: http://www.rust-cure.com/A coating does no perceptible etching as a dipping in acid would, but the Rust Cure bakes on and stays on for years and hundreds of heat cycles and the metal doesn't rust. And use the anti-seize.
