8.75 change out recommendation #1860217
06/30/15 03:03 AM
06/30/15 03:03 AM
Dr Dave Offline OP
Dr Dave  Offline OP
I have a 70 Chally with 8.75, 3.90:1, 340/ 727 and a 71 Cuda, Hemi, 5 speed (T600), 8.75, 3.23:1 ratio that I want to switch around. Would you swap the entire rear ends or just the chunk, which is easier? They are both in great working order.
Re: 8.75 change out recommendation [Re: Dr Dave] #1860228
06/30/15 04:06 AM
06/30/15 04:06 AM
Long Island, NY
shocktrp Offline
shocktrp  Offline
Long Island, NY
Probably just the chunk.
Otherwise you're dealing with leaf springs, brake lines, etc.
Re: 8.75 change out recommendation [Re: Dr Dave] #1860252
06/30/15 08:32 AM
06/30/15 08:32 AM
jersey
Spaceman Spiff Offline
jersey
Are they both large yoke, both small yoke, or is one large and the other small??
Makes a difference with u joint fitment.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 8.75 change out recommendation [Re: Dr Dave] #1860496
06/30/15 01:46 PM
06/30/15 01:46 PM
I'd do the whole axle, just me I dont care to deal with the gear oil mess/end play etc. it'd be heavier lifting but easier in the long run when done. Just have to bleed out the brakes. As said check that both are 7260 or 7290 yokes
Re: 8.75 change out recommendation [Re: Dr Dave] #1860509
06/30/15 02:11 PM
06/30/15 02:11 PM
CA
crackedback Offline
crackedback  Offline
CA
I'd swap the pumpkins.
You going to get back with me about the relays kits and wiring?
Re: 8.75 change out recommendation [Re: Dr Dave] #1860639
06/30/15 05:25 PM
06/30/15 05:25 PM
P
Paul_Fancsali Offline
P
Just change the chucks out good way to change fluid which should be done every few years anyway If ypou run into Ujoint issues get the 7260-7290 adapter u joint.
Re: 8.75 change out recommendation [Re: Paul_Fancsali] #1860823
06/30/15 09:15 PM
06/30/15 09:15 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Cant I just swap out pinion yokes?
Re: 8.75 change out recommendation [Re: Dr Dave] #1860996
07/01/15 12:44 AM
07/01/15 12:44 AM
742/742 yes I believe.
