Leaning out a carburetor How to? #186011
01/06/09 08:00 PM
01/06/09 08:00 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
The 1 barrel 1945 Holley on my Slant six is set on the rich side,plugs are carbon fouled.Which way do I turn the adjustment screw to lean it out?
Re: Leaning out a carburetor How to? [Re: SPWC] #186012
01/06/09 08:10 PM
01/06/09 08:10 PM
Andrewh Offline
Andrewh  Offline
screw them in. But that only affects idle.
does it smoke black while driving?
Re: Leaning out a carburetor How to? [Re: Andrewh] #186013
01/06/09 08:11 PM
01/06/09 08:11 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
If you need to lean it overall, take it apart and check the float setting. you may need to lower the float level so there is less fuel in the bowl, creating less of a column of fluid, and therefore leaning out the fuel mixture.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Leaning out a carburetor How to? [Re: SPWC] #186014
01/06/09 08:14 PM
01/06/09 08:14 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Not sure exactly how to do it on that carb, but changing the jets and air bleed sizes will lean the carb out.
I would suspect if it is a used and dirty carb the air bleeds are clogged and it is "sucking" in too much fuel. They will be small (less then 0.01") holes which can been seen in the throat of the carb (at least on 4bbl holleys).
start there or do a complete rebuild.
Re: Leaning out a carburetor How to? [Re: 6T6Cuda] #186015
01/06/09 08:48 PM
01/06/09 08:48 PM
SPWC Offline OP
SPWC  Offline OP
Doesnt seem like it does(I dont see it) but it smells something awful if its idleing,as It was the other day while I was chit chatting with a friend.
Re: Leaning out a carburetor How to? [Re: SPWC] #186016
01/06/09 08:59 PM
01/06/09 08:59 PM
Andrewh Offline
Andrewh  Offline
Then yeah, screwing in the mixture screw should lean it out.
But, the seat could be damaged, or the needle could be damaged.
While running, screw it all the way in. You should be able to do it with your fingers, do not tighten.
It should kill the car.
If it does not, then shut off the car and pull it all the way out and see if it is still cone shaped. If there is a flat spot or whatever, someone cranked down on it and you are not metering fuel properly.
Re: Leaning out a carburetor How to? [Re: SPWC] #186017
01/06/09 09:06 PM
01/06/09 09:06 PM
choke/choke pulloff
