Re: Went through all that for Nothing...Now What?
[Re: SPWC]
#185989
01/07/09 05:24 AM
01/07/09 05:24 AM
Posts: 511 Jasper, Indiana
fastnos
Jasper, Indiana
Silly question time....
Do you have much fuel in the tank???
A True Hybrid: Burns Gas AND Rubber!
[Re: SPWC]
#185991
01/07/09 10:51 AM
01/07/09 10:51 AM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I dunno how other members feel but when you get the new fuel sending unit in there (as yours seems to be missing a wire) I'd remove the sock from the feed tube and put an external fuel filter. It's a PITA to get inadequate fuel delivery and having to drop the tank every time. Let the dirt roll through and catch it externally. I have 1 filter on the subframe and another just before the carb.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: fastnos]
#185992
01/07/09 11:41 AM
01/07/09 11:41 AM
Posts: 4,884 Michigan
MNobody
I was gonna make a comment about that too, the original post said he shook the tank and didn't hear anything and i thought to myself geez that would be my luck, spend hour's of troublshooting and find out the tank's empty
[Re: fastnos]
#185994
01/07/09 01:13 PM
01/07/09 01:13 PM
RapidRobert
spwc I was wondering why I didn't hear any cussing about having to drain the tank, then when you said it's got 6 gallons in it, enough to give a reading but not enough to spill out.
[Re: SPWC]
#185997
01/07/09 07:12 PM
01/07/09 07:12 PM
Pyper70
Athens, Greece
I dont like those straps anyways, cheaply made these days. You install it on the tube and if you happen to be like this gentleman here removing it and checking things, the tongs snap and its junk. Why not just get a 18" length of solid copper wire, 14 gauge, attach a small hose clamp to it on the tube of the unit and solder an eyelot terminal on the other side of the cable up by where the shock mount is and screw it into the subframe. Thats how my 69 is hooked up.
[Re: 70dart360]
#185998
01/07/09 08:29 PM
01/07/09 08:29 PM
Posts: 1,565 tennessee
pushbutton
tennessee
That wire goes from the windings of the sending unit to the post. Without it theres no way it could possibly work.
When you take it back out you may find that it has a strap making the con. between the reostat and the terminal on the flange instead of a wire. I just went to the shop and looked at one I took out of a 69 B Body.
[Re: 474218]
#186000
01/08/09 12:07 PM
01/08/09 12:07 PM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
I have fixed bad sending units on my 64 Polara and 65 Dart. The Polara's unit had a small sweep arm that rides across the rheostat broken off and I soldered it back on 3 years ago...it's been fine ever since. The Dart's was a little different and I had to drill a tiny hole through the strap mount, then used a shortened finish nail to reattach it. I was planning on just replacing them, but since I was able to repair them I saw no need. They may fail again some day, but for now that's $100 I could spend on other parts. Lucky for me, the Polara's unit sits high in the tank and if there's only a half tank of gas you can remove the unit without draining the tank!
Jeff Adams
64 426 Polara
[Re: SPWC]
#186001
01/08/09 01:18 PM
01/08/09 01:18 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
HOLD ON!!!
Let me ask a REALLY dumb Question. Enclosed I have a pic of a sending unit from Autozone from thier online catalog.It shows a wire(you see it?)
I got to looking at the sending unit I pulled out and reinstalled and there was no wire,and I remember thinking to myself "how does this thing register?" I also saw 2 places with male electrical spades thinking that maybe an "optional" wire went to these.
Guess what im asking is...My sending unit doesnt have the wire like what is pictured,is this normal,or do I need to install that wire?
do you have an original sending unit or an aftermarket unit ? original factory units do not have a wire , they use flat metal as a wire inside ... if i remember correctly ...
then there is this ...
The strap is present.Its a longer one than the one Yearone sells. I cleaned both the outlet of the fuel sender and the inlet of the fuel line where the strap makes contact in order to provide a better ground .
did you check to make sure that your fuel line as actually making good contact to ground ? if it's not the fuel guage will not work , it would be the same as if you didn't have the strap
[Re: pushbutton]
#186002
01/08/09 10:01 PM
01/08/09 10:01 PM
pushbutton
tennessee
