440 Stamped Rockers? #1859996
06/29/15 10:00 PM
06/29/15 10:00 PM
S.E. WI
RichL1967 Offline OP
S.E. WI
Are the shaft holes in 440 Stamped Rockers supposed to be round?
Some of the originals are more out of round than others so I thought that they were worn and bought new ones from Summit. But, the brand new ones are worse out of round than the "worst" original one. Should I be returning these?
Re: 440 Stamped Rockers? [Re: RichL1967] #1860021
06/29/15 10:10 PM
06/29/15 10:10 PM
Kirkland, Washington
Pacnorthcuda Offline
No they are not round. Only the bottom part is a bearing surface, from about 4:00-8:00 on a clock face as viewed from the side. What you are seeing is normal.
